OK so I got an 88 ecu for my 87 quest and when I pulled the old ecu out it was also from an 88 at least that is what was marked on it in black marker, so I looked at the numbers between the two and they are all the same except the 88 I was putting in had a A on the end. Here is what the numbers are maybe somebody can tell me what the difference is, here are the numbers for the one that was in the car when I got it and is marked 88 quest #E2T13674. Ok here are the numbers for the one that I put in that is also marked 88 quest # E2T13674A, notice it has the A on the end ?. there is also a bigger number above the smaller numbers on the label on both ECUs # 6394, not sure what all these numbers mean but maybe you guys can help me, thanks.
88 ECU
Started by 03CL55AMG, Jun 30 2011 09:57 PM
4 replies to this topic
#1
Posted 30 June 2011 - 09:57 PM
Forged motor, weisco pistons ,3" exhaust, garret 60 cold/ 70 hot turbo, bosch 1000cc injectors. meth kit. chads intake and header. holly EFI stand alone. *DM intercooler. grimspeed boost controler. stock cam.
#2
Posted 30 June 2011 - 10:16 PM
The bigger numbers are the ones that matter. The 6394 is an 87 ECU, unless the internals have been swapped. 88-89's end in 0197.
#3
Posted 01 July 2011 - 05:32 AM
as i recall 87 ecu's are mount'd connectors up,,88/89 ecu's are mount'd connectors down , you may have an 88 not an 87 , most 87's with 88 ecus still have the 87 ecu case but with 88 internals
the 87 ecu had a single board the 88/89 had a smaller daughter board mount'd on top of the base board
88TSI Silver
89TSI red auto
88TSI Silver
89TSI red auto
#4
Posted 01 July 2011 - 12:21 PM
1984
Ignitor
MD071942
1985/86
Ignitor
MD071942
MD093767 "P" series
1987
Ignitor
MD109942
1988/89
Ignitor
MD125748
1984
ECU
MD071084 Manual
MD084583 Auto
1985
ECU
MD084582 Manual
MD084583 Auto
MD090798 "P" series manual
1986
ECU
MD101175 Manual
MD101176 Auto
MD101177 after 10/85 w/intercooler
1987
ECU
MD111820 Manual/Auto
MD106394 w/intercooler
1988/89
ECU
MD120197
1984
Distributor
MD061593
Governor set
MD607784
Vac Adv Unit
MD607785
1985/86
Distributor
MD061593
MD093766 after 12-84
Governor set
MD607784
MD611368 for 3766
Vac Adv unit
MD607785
MD611360 for 3766
1987
Distbibutor
MD109937
MD109938 w/intercooler
Governor set
MD607784 for 9937
MD611368 for 9938
Vac Adv Unit
MD611360
1988/89
Distributor
MD119754
Governor set
MD611368
Vac Adv Unit
MD611769
Ignitor
MD071942
1985/86
Ignitor
MD071942
MD093767 "P" series
1987
Ignitor
MD109942
1988/89
Ignitor
MD125748
1984
ECU
MD071084 Manual
MD084583 Auto
1985
ECU
MD084582 Manual
MD084583 Auto
1986
ECU
MD101175 Manual
MD101176 Auto
1987
ECU
1988/89
ECU
MD120197
1984
Distributor
MD061593
Governor set
MD607784
Vac Adv Unit
MD607785
1985/86
Distributor
MD061593
Governor set
MD607784
MD611368 for 3766
Vac Adv unit
MD607785
MD611360 for 3766
1987
Distbibutor
MD109937
Governor set
MD607784 for 9937
MD611368 for 9938
Vac Adv Unit
MD611360
1988/89
Distributor
MD119754
Governor set
MD611368
Vac Adv Unit
MD611769
#5
Posted 01 July 2011 - 12:32 PM
Thanks guys, looks like i had an 88 unit in there already the one i had pulled out had 0197 in marker written on it so I will check to see what I put in may be an 87 ecu.
