sqall12001 Posted November 21, 2012 Report Share Posted November 21, 2012 I'm having issues with my right pop up motor, I tested at the relay and have 6 volts where I don't think I should. I want to remove the motor and sensor and clean/grease them. Does anyone have advice on how to remove the motor. -Nick Link to comment Share on other sites More sharing options...
patra_is_here Posted November 21, 2012 Report Share Posted November 21, 2012 (edited) what sensor? the one internal to the mechanism? Edited November 21, 2012 by patra_is_here Link to comment Share on other sites More sharing options...
patra_is_here Posted November 21, 2012 Report Share Posted November 21, 2012 also, swtich left and right relays first and see if anything changes. you got some troubleshooting to do before you go pulling crap apart. Link to comment Share on other sites More sharing options...
sqall12001 Posted November 23, 2012 Author Report Share Posted November 23, 2012 I did a bit of trouble shooting. Power going to the relay, there its an odd stray 7 volts coming back from the pop up motor. And I doubt the motor had ever been apart so I would rather do some Maint On it. Link to comment Share on other sites More sharing options...
sqall12001 Posted November 23, 2012 Author Report Share Posted November 23, 2012 I did a bit of trouble shooting. Power going to the relay, there its an odd stray 7 volts coming back from the pop up motor. And I doubt the motor had ever been apart so I would rather do some Maint On it. Yes I have switched relays, the ones I have had apart, cleaned, Di electric greased, and reassembled. Link to comment Share on other sites More sharing options...
patra_is_here Posted November 27, 2012 Report Share Posted November 27, 2012 well, from what I remember, if you pull off the front panel and headlight covers/plastic you should be able to access the motor assembly. Link to comment Share on other sites More sharing options...
ucw458 Posted November 27, 2012 Report Share Posted November 27, 2012 well, from what I remember, if you pull off the front panel and headlight covers/plastic you should be able to access the motor assembly. Or you could just reach up from under the car. Nothing in the way there. Link to comment Share on other sites More sharing options...
sqall12001 Posted November 28, 2012 Author Report Share Posted November 28, 2012 Sounds good. Thx,-Nick Link to comment Share on other sites More sharing options...
