Mopar Magnum 360 / 5 Speed Swap
54 replies to this topic
#21 sdrt
sdrt
  • 202 posts
Posted 07 July 2015 - 01:44 PM
Put the coilover assembly on to measure tire and wheel fitment.  Both front and rear wheels are the same.  18x11.  I don't believe I will go the wide up front. It kinda looks funny.
#22 importwarrior
  • 18,362 posts
Posted 07 July 2015 - 07:39 PM
Love those wheels!!!!!!!!!!
#23 Crazy larry
Crazy larry
  • 2,061 posts
  • Interests:Cool Cars
Posted 16 July 2015 - 05:22 PM
liking the Garage Art :)   keep at it, looking good so far.  I too Like the Wheels
87 Atlantic blue v-8   89 Fiji blue unmolested stock low mileage.  Daily driver 87 Black. 88 white Drift car..SOLD
#24 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,412 posts
Posted 17 July 2015 - 09:34 AM
MOPAR FTMFW  ;)  i'm diggin' this build dood
i'd cut the trans tunnel & floor up to the frame rail and build a house/console. you could always take it out for service,  adjustments,  etc. i'd also go with a rack for steering.
easy for me to say looking back  -_-
          MOPAR POWERED
#25 sdrt
sdrt
  • 202 posts
Posted 17 July 2015 - 02:49 PM
Thanks guys, it has turned in to quite the project.  I think I may do something similar with the tranny tunnel.  My main concern there is the slave cylinder is in a pretty terrible spot.  As for steering, I would love to swap over to a rack but around here they are a little harder to come by.  Not to many parts cars to steel it from.  I am running in to the same problem you have in your write up.  The exhaust on the drivers side is becoming a problem.  I’m either going to have to go your route or try and swap sides with the magnum manifolds and run the drivers side over to the passenger side and run one larger pipe out the rear.
#26 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,412 posts
Posted 22 July 2015 - 11:56 AM
i originally wanted to do a single 3 or 3.5" but my bud talked me into the true duals ,  either way is cool
          MOPAR POWERED
#27 Xtreme Industries
Xtreme Industries
  • 1,538 posts
  • Interests:cars
Posted 24 July 2015 - 02:49 PM
those wheels are awesome
1991 BMW 318i - RIP
#28 sdrt
sdrt
  • 202 posts
Posted 26 July 2015 - 10:01 PM
Finally got the car on all fours.  The rear coilovers are set about half way and the fronts are close to the bottom.  I thought that my lean in the rear would go away by replacing all of that stuff but it hasn't.  Anyone know what's going on here so I can fix it?  I pulled it out of the garage to get the rest of the the bay and wheel wells degreased and cleaned.  Makes it easier to finish the swap.
#29 sdrt
sdrt
  • 202 posts
Posted 26 July 2015 - 10:07 PM
Here is what's left of the front end damage from when I got the car. A friend of mine has a frame table to try and get it straight as we can.  I will be putting wheel tubs in and caging the car.  At the same time I will make a tube front end to mount all of the stock hardware to.  I also scored a front bumper and air dam finally
#30 autotr8er2
autotr8er2
    Out of my Cotton Pickin' Mind
  • 993 posts
Posted 27 July 2015 - 07:29 AM
regarding the lean, have you check if the rear subframe is tweaked?  Block the body of the car with the suspension hanging (remove the wheels) and measure the four mounting points from the ground.  With the front end damage you pictured, that's a pretty good hit. Another possibility is the bushings are wore out.  My two cents.
#31 autotr8er2
autotr8er2
  • 993 posts
Posted 27 July 2015 - 07:35 AM
On the slave cylinder, it looks like the connector has an o-ring seal and a spring pin holding in place.  There are AN fitting adapters that will allow you to take the bulky connector off and put in a 90 degree for clearance.  Summit has one that may work.  http://www.summitrac...CFUgWHwodUPAJiQ
Good luck in your search.
Edited by autotr8er2, 27 July 2015 - 07:36 AM.
#32 Crazy larry
Crazy larry
  • 2,061 posts
Posted 08 November 2015 - 03:00 PM
More Pics
#33 sdrt
sdrt
  • 202 posts
Posted 01 January 2016 - 04:23 PM
Alright back in to this car.  I'm fitting the motor and am ready to mount.  I have a few questions for you guys.
I had read somewhere that our motors were mounted not directly in the center.  I'm trying to find what that measurement was so I can offset my drivetrain.  Anyone know what it is orginially?
- I'm hesitant to weld in the motor mounts and redo the crossmember until I can see how bad the front frame damage is.  Can anyone help me out here with some kind of measurement for the frame rails?  I attached some pics of the damage up close.  I was thinking about cutting the top of the rail out in the damaged areas and hammering it back close enough to weld in a new rail.  Unless someone has a parts car I can steel them from.
#34 autotr8er2
autotr8er2
  • 993 posts
Posted 02 January 2016 - 01:06 AM
There are two structures that make up each of the frame rails.  An inner "horn" and the outer one. Not sure how I'd approach it, myself.
#35 sdrt
sdrt
  • 202 posts
Posted 08 February 2016 - 05:19 PM
I got the frame straightened at a shop and it came out pretty good.  They said the front of the car was about and inch off to the passanger side.  Everything should be pretty straight now.
I received my headers last week from summit.  It looks like the drivers side is going to need some love to make it fit.
#36 sdrt
sdrt
  • 202 posts
Posted 08 February 2016 - 05:35 PM
Now with a smaller dilemma.  Where the motor should be placed.  If I absolute center the motor the valve covers hits the brake booster.  The farther I move the motor to the passenger side It makes the shift not centered. I'm trying to find a happy medium here.
Getting closer to fabbing some motor mounts.
#37 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,412 posts
Posted 11 February 2016 - 10:57 AM
dood believe me, do a rack
          MOPAR POWERED
#38 sdrt
sdrt
  • 202 posts
Posted 23 May 2016 - 03:48 PM
The motor and tranny are finally supporting themselves.  Everything is tacked in to make sure this is how I want it before I final weld it all.  As you can see from the steering arm and I am now going to be fighting with some room (With or without rack steering IntercooledFlatty) This project has been going so long I just want to get the damn thing on the road.
IntercooledFlatty - Did you just fab a one piece driveline to the torque tube?
#39 sdrt
sdrt
  • 202 posts
Posted 23 May 2016 - 04:05 PM
I also picked up my fuel delivery stuff.  New intake and fuel injection.
#40 button
button
  • 2,028 posts
  • Interests:1978 Plymouth Arrow
    1974 Dodge Colt
    1990 F45 Tow Rig
    2011 Honda CR-Z
Posted 31 May 2016 - 09:47 AM
I've been hearing a lot about Fitech. I'll be interested to know how this works out.
Just curious what that setup ran (intake/injection system)?
-Jay
