jwbrocloud Posted April 13, 2009 Report Share Posted April 13, 2009 Ok, so say I had a quest with a 4g63 swap in it but the guy who did the swap did not go with the 4g64 wide block but with the 2.0 liter narrow and bolted a d50 tranny to it. I am thinking that when i rebuild the engine i should go back with a wide block and swap back in the starion tranny. My question to yall is is it worth it? Or will the d50 tranny hold up well to my fully built narrow block??? Has anyone run the d50 tranny for a while? And with what results. Thanks, Jonathan Link to comment Share on other sites More sharing options...
StarquestRescue Posted April 13, 2009 Report Share Posted April 13, 2009 Ok, so say I had a quest with a 4g63 swap in it but the guy who did the swap did not go with the 4g64 wide block but with the 2.0 liter narrow and bolted a d50 tranny to it. I am thinking that when i rebuild the engine i should go back with a wide block and swap back in the starion tranny. My question to yall is is it worth it? Or will the d50 tranny hold up well to my fully built narrow block??? Has anyone run the d50 tranny for a while? And with what results. Thanks, Jonathan From what i have read they don't hold up well. A 88/89 starion trans will do better but, A Bill housing is probably the best bet for a long term solution. http://www.starquestclub.com/forum/index.p...c=82080&hl= http://www.starquestclub.com/forum/index.p...c=82168&hl= Link to comment Share on other sites More sharing options...
jwbrocloud Posted April 14, 2009 Author Report Share Posted April 14, 2009 Nice . . . that does look like a good way to go. Is there any other Rwd trannies that will bolt to the narrow block? Link to comment Share on other sites More sharing options...
lionbull Posted June 18, 2009 Report Share Posted June 18, 2009 the t5 is a better buy than supra tranny, more part to upgrade, stronger, same weight as starion tranny, no modding of tranny tunnel got atleast 10 more reasons. get the one fom the turbo coupe its hydraulic, for cable the 5liter will do. Link to comment Share on other sites More sharing options...
underpaidslave Posted May 24, 2011 Report Share Posted May 24, 2011 the t5 is a better buy than supra tranny, more part to upgrade, stronger, same weight as starion tranny, no modding of tranny tunnel got atleast 10 more reasons. get the one fom the turbo coupe its hydraulic, for cable the 5liter will do.So the t5 bolts up to the narrow block 4g63 without an adapter plate. Link to comment Share on other sites More sharing options...
jayfressh Posted May 24, 2011 Report Share Posted May 24, 2011 So the t5 bolts up to the narrow block 4g63 without an adapter plate. No, he forgot to mention that one reason why it wasn't so great..... Link to comment Share on other sites More sharing options...
socjdqcer Posted May 30, 2011 Report Share Posted May 30, 2011 Im using a t5... Its a great tranny! Link to comment Share on other sites More sharing options...
