- 1552 views
- 18 replies
- 11678 views
- 690 views
- 23 replies
- 12948 views
My mods
By Twisted_Conquest,
here are my mods.
17C turbo
no cats
3.75in down pipe
3.5 straight pipe (dumps out the side of my car (in front or rear passenger side tire (no muffler just a nice oval tip hehe)
2.75 hard pipes (thanks to chad in oregon)
greddy BOV
greddy turbo timer
MBC (paid 7 bucks for it i have the website so if u need one cheap just let me know)
new head (with jet valves removed) thanks to PumpedTSI
air can removed with custome setup
accel blaster
msd ignition (not in yet)
8mm wires
just orde
Ignitor Box Mod 88/89 only..ECU upgrade for pre-88
By norats,
WARNING 1988-89 only! The igniter box on stick-shift cars can be tricked into allowing 10.5 psi boost by moving one wire - basically, the wire that determines if the car has an automatic or manual transmission. Step by step: 1) with the engine off, key out of the ignition, unplug the battery. 2) Locate the 2 millimeter thick black+yellow wire (black wire with a yellow stripe) at the igniter module near the ignition coil. Cut the wire near the connector - on the igniter side of the con
Good QUEST Mechanic listing buy state
By gene1,
I live in Rhode Island and need a Highly skilled mech. to swap all the high perf. stuff from a wrecked conguest to a stock starion....Its got $16,000 worth of Modds...CMN #4 suspension.....Parts would enclude: eng., turbo, struts, tranny, turbo timer, elec. box for two extra injectors, radiator, 3" exhast........Will pay $2000. for job done complete ;please help.
Keeping your Starquest Cooler....
By KO,
Here are some things you can do to keep your car running cooler.
1. Get your radiator rodded, usually $40-$50. Your radiator is over 12 years old and it's probably nasty. Â
Rod Out - Rodding out a radiator means to remove usually one or more tanks from a radiator and to insert a flat rod, which is smaller than the width of the tube, into the tube by pushing that rod through until it comes out the other side of the radiator or core.This is done repeatedly through all the tubes in the radiator.
