- 17 replies
- 2537 views
- 962 views
- 13 replies
- 2231 views
- 810 views
RAD fan switch PN for 190 degree switch
By importwarrior,
Subject: RAD fan switch PN
for those that dont know and want to keep things cool!
front rad fan switch part number 190 Degree
stock right hand side ( passenger side when sitting in the car)
AutoZone P/N Wells SW-508 190 Degree
i installed 2 in my car. one on each side
now both fans kick on at 190. i have a 180 therm stat also
190 degree fan switch PN
By importwarrior,
AutoZone P/N..... Wells SW-508 190 Degree
Fog lamp rewire specific instuctions
By fastquest,
I figured it out and now can give you specific instructions on how to wire your fog lamps to work with parking lights on, they will work normally with the switch while just  the parking lights are on or the headlamps are on, or both, but still retain the saftey feature of going off when you put the high beams on. I removed the factory low amperage relay and replced it with a bosch 30/40 amp relay, this will allow you upgrade the stock 35 watt bulbs to the new H-3 plasma type high wattage colore
how about this
By jpmilkovich,
add battery relocation instructions to the FAQ board. it might prove helpfull for some
