- 459 views
- 7 replies
- 721 views
- 1 reply
- 1007 views
92mm je forged pistons
By doobie360,
have a set of used 92mm je performance forged pistons dont know compression ratio, i had got a mic measurement on them when i had the carbon build up cleaned off, but i dont remember the exact measurement it was 91.8 something something , also have rods from 87 conquest tsi 2.6 but no rod caps ( so they are junk from what ive been told) that will come with them, rods would make good paper weights or something. pistons are used mileage is unknown BEING SOLD AS IS 250 firm! best way to contact is
ok dropped tank to check pump and crank signal ....
By markhansenconquest,
Tank is half way down....pump is out ...hooked up to battery and works...checked when in car 38psi at engine bay filter...Can pump be 38psi and not be strong enough to start car??(car will run after starting with fluid )...will check for power to pump when cranking with light tomorrow..........hard to check for signal and turn engine over at the same time ..........ha ha.........looking at pg 14-26 and 14-27 FSM 86...checking ECI system ....will be doing tomorrow...... any ideas???
tail of the dragon meet
By jaytaylor,
Hey I just moved here from Detroit (drove my 86 quest) I would like to cruse the tail of the dragon would like it if there was more than one quest.
