- 6 replies
- 1208 views
- 772 views
- 14 replies
- 863 views
Wiring Diagram for Digital Dash
By T-Harps,
My voltage gauge and oil pressure gauge both stopped working at the same time on my 85's digital dash. This happened about half an hour before my fuel pump failed and left me on the side of the road. I'm pretty sure its the fuel pump because the pump gets voltage when cranking but no fuel comes out at the TB inlet fuel line. Does anyone know what could cause the gauges to die or if the gauges could be related to the fuel pump? And where could I find a wiring diagram for a digital dash? Thank
Starion misfire issue
By Mach 5,
Having a weird issue... It misfires only under part throttle and at idle but he second you crack it to fuel throttle it runs perfect and has full power.. No smoke whatsoever.. Car sat for 10 plus years until I purchased it. Head gasket was blown.. repaired with milled head and new gasket. Installed new Trilogy fuel injectors.. fuel system has been flushed new pump filters injectors regulator o2 sensor fuel injector clips plugs wires cap n rotor tps and isc has been reset. Also checked for vacu
not starting now
By Nightcall,
Hi guys ive been cleaning and flushing my radiator of rust. Prior ive new sparks wires dist and cap. I left prestone flush + water in rad. I drove it a bit like instructed (5 miles) and entire ebngine bay is steaming and im overheating. Why?. Next thing i know my car wont start. Can you give me your opinions? Thx
