- 41 replies
- 3689 views
- 10 replies
- 1439 views
- 6 replies
- 953 views
- 1167 views
New motor and turbo build
By questtuner82,
Ok so im building a new motor and turbo. Specs of motor... .40 over with je custom pistons 7.5:1 c/r, custom carillo h beam connecting rods, block is race prepped with webbings machined down. Race prepped crank lightened knife edged renitraded with chromed journals chamfered oil holes. Balanced rotating assy bse kit block was zero decked. Amc marnel head with 2" and 1.6" stainless valves maganese bronze valve guides heavily ported and polished chambers are smoothed and polished and cc'd custom g
Coolant high temp sensor that shuts down the A/C
By BandY,
Can someone help me learn where to buy this part? The chain stores don't even list the sensor. It's usually the highest sensor in the thermostat housing, I'm pretty sure. The lowest is for the gauge, and the other is the coolant temperature sensor. The one I'm referring to has very small threads, and it's mostly made of brass, with one single plug. If the engine temperature gets too high, this sensor stops the ground to the compressor, and shuts down the a/c. Thanks for the help.
How to rebuild cv halfshafts?
By jeph_tsi,
Curious, with our axles and many others being nla, is there any good place to get parts to rebuild? I need to rebuild an axle that is hard to find, non sq.
new starion owner (for the second time) could use a little help
By justin240,
alright so just to start off, i finally bought a second starion, i had one a few years ago, bought it, put a clutch in it the next weekend, and then lost my job the weekend after that and had to sell it (been sad about it ever since) so after a few years i finally stumbled back asswards into a second one, this one is an 87 last one was a 86 both widebodys (love the look) so just to start with the list i have recieved on this particular car as told from the previous owner, my research has pro
