- 7 replies
- 737 views
- 61 replies
- 5654 views
- 13 replies
- 1348 views
Need a transmission
By 86munster,
I need a transmission for my 86 starion, the closer to eastern ct the better, have cash in hand and willing to pick up if close enough thanks brian
Engine not firing
By gribbs1469,
Ok ya'll I have a problem and i can't figure it out.I have a 1987 all stock widebody. I just rebuild the motor and installed it, hooked up all the lines, wires, etc. I have spark, I have fuel now I had to change the pump. checked the injectors, primary is firing. Checked and rechecked timing. The last thing i did was pulled the TB off the intake and there was a puddle of fuel in there. it was actually covering the whole bottom of the intake about a half inch deep. I had pulled the plugs about 10
89 PARTS
another alternator question
By roman88,
hello guys, Ive been having trouble with my charging system like im sure a few have had. i just replaced my alternator (still stock) and im still noticing my juice being drained. i changed the flasher and it helped but still having problems. This weekend im gonna focus on just cleaning all the grounds, fusible links and anything i can find. i used to have a 12" kicker sub with a 400 kicker amp. i took it off. i wanna use it again but i know the stock alt. is only 75 amps and i dont wanna burn
