- 4535 views
- 4500 views
- 14 replies
- 1116 views
Distributor install
By importwarrior,
When installing the Distributor the marks are supposed to be aligned like the pic below BEFORE the TEETH MESH with cam gear. http://i37.photobucket.com/albums/e82/silverquest/PQ%20manual%20pics/album_pic-15.jpg once seated all the way in and the cam - dizzy gears are meshed properly, the marks do not align anymore. it should look like the pic below. in the Pic below... it is hard to see but the Dimple has rotated slightly towards the front of the head. or front of the car. this is
Fuel and Oil line to -AN fitting sizes
By importwarrior,
Information provided by: NightWalkerAncestery Just got done doing this to my 87. It's a good idea to do. I would also do the flex line from the fuel pump to the hardline as it almost ALWAYS rusts out at the 90* curve and maybe even the hardline to fuel filter. I used metric to AN adapters for the fuel filter for better flow. 90* on bottom and straight on top. Here's a list of everything you would need if you did things the way I did. I'm not currently sure of the power steering lines, but I
syncope
By twojayzeestarion,
Anyone else on here randomly pass out regularly. If so what triggers it for you and how have you found to control it
