- 4 replies
- 751 views
- 10 replies
- 981 views
- 12 replies
- 1336 views
Help with Civic Auto Trans Leak
By BoostedBimmer,
Ok, I was wondering if there were any Honda experts here? My 95 Civic (auto trans) just dumped all its trans fluid out (leaving a huge pool of trans oil on my driveway). I checked the following so far of possible areas where it can leak, and these areas are all fine: Transmission cooler lines (all dry) Both driveshafts where they enter the trans (all dry) Dipstick (on tight) Transmission drain plug (dry) I didn't take off the torque converter cover yet, but it appears all dry behind this c
Smoke rings out the exhaust... Turbo?
By 83stariontravis,
Very obviously oil smelling blue smoke. Turbo is kinda wiggly and I'm leaning toward the idea that it is oil burning out of the turbine side of the turbo as the induction pipes are pretty clean. The spark plugs all look a tad rich but all the same and as clean as can be expected, no obvious bad cyl. Does not do this until the car is just about fully warmed up and it seems to be a little intermittent but I'm not sure why. This is not a new problem has done it for a while but not bad enough to
JVE remove rocker assembly?
By ticktown,
Hello: I have an '86 Starion with hydraulic lifters. I'm finally getting around to eliminating my jet valves with the kit I got from Dad. I have the rocker cover off. Do I have to remove the rocker assembly or is there a way to get the jet valves out with the rockers still in? Many thanks.
