Albatross
Everything posted by Albatross
I doubt that you'll do it for another $500. An easy to install system runs at least twice that much. Megasquirt is cheaper but requires in depth wiring & programming. Then you have to get intercooler tubing & boots, fuel fittings, fuel pump & decide on an ignition system.
will be getting a standalone soon need input?
Albatross replied to ls1rx7's topic in MPI/Standalone Trials and Tribulations
Be prepared to spend LOTS & LOTS of time setting up & tuning. Spend a week reading all the instructions before you start. Here's a link for Megasquirt. You may want to browse through it to see what you're facing. http://www.megasquirt.info/ms2/ If you have friends that you can rely on to help you to the end, you might want to go with their recommendations. Haltechs are a bit pricey though. -
IMPORTANT NOTE: Do NOT burn tables ('Calibrate AFR Table' or 'Calibrate Thermistor Tables') on a running engine. Even idle is NOT allowed, because these tables ONLY exist in flash, so once a table is erased, there is nothing but garbage in there until it is re-programmed, one word at a time. Until that reprogramming is complete, operating the engine is unsafe. Ok, I did that: calibrated thermistors with engine running. MSII, V3, variant 028. So how do I do this reprogramming? BTW, the thermistors show accurate reading now. Is reprogramming still necessary?
I'll take a galvanized set because it's getting painted next week. Paypal?
I need a set if available; going to paint it next week.
You can get it all on ebay under megasquirt. Mounting the pickup wheel needs to be precise. The bracket for the sensor must not flex either. The megasquirt must be set up for EDIS. Wiring is tedious. The wiring for the sensor & coil appears backwards on some diagrams.
EDIS variable VR signal, no spark
Albatross replied to Albatross's topic in MPI/Standalone Trials and Tribulations
The VR sensor wire switch did it. Thanks! I'll post everything here when it's done. I need to get the Megasquirt running next. -
Albatross posted a topic in MPI/Standalone Trials and Tribulations
I can get a 12v square wave PIP signal with Megasquirt unplugged, but it drops to 5v when plugged in. Even witrh Megasquirt unplugged, when EDIS should still give ground pulse to coil, I get no pulse. VR signal varies in amplitude, probably due to skinny toothed wheel bolted to pulley, but it has a rested .5v on the DVOM. Can the variable VR signal cause the lack of ground pulse? I've tried 2 different modules & VR sensors, & had one module tested & verified working. -
how are those injectors held into the manifold?
I'll take it. PM sent.
I could use a good TPS & knock sensor (not the box).
Good TPS & Knock Sensor needed
Do you have a good TPS?
Do you have a TPS?
I'll take them. Give me total price with shipping to 45368 & paypal addy.
How much for a gearshift boot for manual trans? (the big boot on top)
Interested if good
50% off sale MOOKEEH MK1 REAR UPPER STRUT BAR
Albatross replied to 101PROPOSE's topic in Parts for sale
Now I need the front one. Still $129? How about shipped? -
I got my engine parts back from Randy all sealed in plastic. This guy is a real pro: knowledgable, friendly, professional.
He really knows his stuff. He just did my machine work & I'm very pleased.
Star-Orion Performance 3-gauge panel pod 3RD RUN COMPLETED!!
Albatross replied to a topic in Group Purchase Info
Tension won't hold it half way around the autocross course. -
How is this supposed to stay in place? There are no anchor points on it. -
Paypal sent. Thanks!
