Tyler.quest3666
Everything posted by Tyler.quest3666
How much for center console with radio bezel. And a pillars? I hope everything turns out okay for you very sad day... And do you have a front air dam if so let me know Thanks...
Black it is...
Aem uego and more questions...
Tyler.quest3666 replied to Tyler.quest3666's topic in Newbie Question and Answers
Sweet thanks just wanted to make sure it wouldn't screw up my A/F reading.. update tested my switch for my windshield wipers the on off switch is not working... -
What kind of RTV did you use and how is it holding up? (No slow leaks)...
I'm installing a boost gauge as well can I run the same switched power to both gauges? I Will be using two different grounds and they will have there own in line fuses. -
Sweet thanks Scott after I fix my wipers I'm throwing in a maf-T and 3 inch gm maf any tips? -
Thanks for the quick response I really appreciate it. Just want to do it right on the blue connector the two red wires are both switched power correct? And as for the wipers the speed of the wipers work fine but the on off switch is probably bad I'll dig into that and thanks again. -
Dont want to sound dumb but I'm Installing AFR gauge. what ground do I use? the actual ground that is wrapped around the 02 sensor wire or the ground next to the Ecu? Also what and were is a good switched power I was going to use the radio but I've heard it might screw with the gauge. Secondly my windshield wipers will not stop going unless I unplug the motor. I have cleaned the old grease out and cleaned the connections and it still won't stop Thanks in advance.
7 bucks for the wiper motor. Awesome thanks buddy!
- 9 replies
- hood latch
- oil cap
(and 5 more)
Tagged with:
How much for the wiper motor shipped to 84075?
- 9 replies
- hood latch
- oil cap
(and 5 more)
Tagged with:
1987 Part-Out due to engine swap. More to come!
Tyler.quest3666 replied to Scary_TSi's topic in Parts for sale
How much for the trilogy injectors, rubber shift boot, and the turbo gaskets? If still available. -
Do you still have a radio surround, air dam and is the red driver side front fenderin good shape?
Three shp and one non shp struts
That's a killer deal. The right ups on them are pretty detailed. I'm sure I could do it. Might have a few questions and I'll keep you in mind. Thanks for the help. -
My 88 that I just purchased has three shp struts and one (non) shp strut "that is blown by the way". what can/should I do about it? After I get her running in tip top shape I planned on lowering her a few inches with Mk1 coils.
89 shp front struts,,decent shape...or for your D2 swap
Tyler.quest3666 replied to quikconq's topic in Parts for sale
Are these still available? If so can you give me a shipping quote to 84075 -
I'm located in Syracuse.. and thanks for the welcomes guy's.
Just picked up a 88 conquest driving project car. most likely will turn into a little daily drift car. already dropped the tank and got all the rust out and a new pump. Needing a good radiator to keep the temps down. Already took care of the fan's.
