TheLadiesMan
  • Interests
    CARS!!!
    East Windsor NJ
  • ICQ
  • AIM
    biocloge12
TheLadiesMan's Achievements
  1. Hello.. I'm looking for a clean starion 88-89 black rolling chassis in the northeast, particularly NJ. Let me know people..
  2. Ahh yes.. Also could use that lower trans shield.. you know what im talkin about..
  3. I could also use a bunch of oil pan bolts.. Emergency brake cable.. The bottom left tranny bolt.. (facing from the driver seat) Maybe a clutch master and slave cylinder.. I'd prefer it that they worked.. :wink: Might think of other stuff.. Pullin my motor for a rebuild now..
  4. I need the third pulley for the a/c.. I guess thats the idler pulley.. the one to adjust the belt tension.. I need the whole bracket and all the bolts to bolt it up and what not.. the belt would be nice too.. Also need the special 2 piece bolt thing for adjusting the alternator belt tension.. You know.. the bolt with the hole in the head and you thread the other bolt into and tighten/loosen to adjust belt tension.. blah blah blah.. Both bolts please.. Thanks let me know
  5. I need the third pulley for the a/c.. I guess thats the idler pulley.. the one to adjust the belt tension.. I need the whole bracket and all the bolts to bolt it up and what not.. Also need the special 2 piece bolt thing for adjusting the alternator belt tension.. You know.. the bolt with the hole in the head that you thread the other bolt into and tighten/loosen to adjust belt tension.. blah blah blah.. Let me know peeps..
  6. Tried that one after reading your original ideas... Nope, doesn't work.. Don't MBC typically only handle like 7 PSI? The one that came on the car is so old I guess I can't find any info on it..
  7. Alright, well neither of those ideas work for me.. But i'm trying to hook in a manual boost controller.. How much PSI can a typical MBC control? Mines an old Turbo XS one (its plastic) I've tried a million different ways. I've had my boss (professional mechanic) try it, i've had a fellow Starquest owner give me ideas, and i've experimented with it myself for hours and I have most of them written down. Whats going on? Is it because the MBC can't handle the 15 PSI i'm trying to get it to run? The car either runs with 7 - 10 PSI which isn't enough.. the car loses all power at 3kRPM.. or its running 25 PSI.. which is obviously way to much and I could blow my already busted motor. Thank You
  8. Great Seller! Quick and easy communication. Recieved items with overnight shipping as requested. Thanks a bunch
  9. I just ordered mine.. Total of 16 now.. These gauges look great and so many options for customizing.. Go look at it guys..
  10. I'd be interested in a 83 style CF hood.. If this went through
