TadsQuest
    3
Everything posted by TadsQuest
  1. New Product Available! Cannonball Run II - Rocker Panel Livery (Not AI) See details in the photo and feel free to message me for specifics. I also want the price to be more competitive, but for that I would need to consider group buy or if someone on here has connections with vinyl wrap printing. Thanks for looking!
  2. I had success disassembling the canister. I found the tear in diaphragm and smeared both sides with gasket maker. Car is parked for other reasons so I can't say the longevity. But it deff worked after for months. Maybe it will at least let you confirm that's your issue. Or measure the diaphragm to find a suitable replacement.
  3. Those are sick! Tux have you ever had any success from yahoo Japan? I had a friend into it, but wasn't sure how fruitful it was
  4. Have you used Send Cut Send? They are a great online platform for getting simple bracketry made in small or large batches.. if you like your prototype, upload your cad file to their website, select your material and finishes (they can powdercoat).. and you'll be given an instant quote for how much at different purchase volumes.
  5. Looks great! Any tips for polishing the tips so well? I love the stock dual tip on these. Also - how about your starion front grille... custom? Its sick!
  6. As an audiophile I always struggle with the balance of period correct and good sound. I love this idea and never seen someone use a background screen like that. Cool! Does this unit let you choose a splash screen? If so, what did you go with?
  7. Just a tip: when searching this site go to google and type in what you want with "starquestclub" after it. For exanple, "abs delete starquestclub"
  8. Check the vacuum line inder the fpr to the throttle body, it should be dry. If theres gas in it the diaphragms bad
  9. Check the vacuum line inder the fpr to the throttle body, it should be dry. If theres gas in it the diaphragms bad
  10. I got it fixed it was the CTS, thanks!
  11. Dad sells the pair, but they aren't push to release http://www.enginemachineservice.com/conquest.html
  12. Alright so I hooked a 300ohm resistor to the CTS plug and it didnt help, it didn't change it at all. Also I checked the plugs and they were completely dry, not black, and did not smell like gas. Any other ideas would be helpful. Thanks again. Also the bog i'm talking about under load is the boost gauge (stock) going up to zero but low RPMs, as if I was going up a hill.
  13. Dad also sells this rebuild kit. I think his site is enginemachineservice.com
  14. Okay ill try it, thanks for the help Bill. If it was too rich would it cause it to bog under load like it does?
  15. The problem is, i need the plug to think its not at operating temp, so it will tell the ecu to give it more gas.
  16. Thanks ill try it asap. And indiana why would i do that when my idles fine at operating temp.? Its specifically when coolant is cold.
  17. Also if its been sitting in the sun for a while and i start it up its fine, its only when the engine temp and outside temp is cold.
  18. I havent checked it but it should be good cause if i keep my foot on the gas a little it stays running, only if i let off it stalls.
  19. I had same problem and had my turbo rebuilt, cleared it right up
  20. When does it not start up? Just if its sat for a while? If you let it warm up and shut it off will it start right back up?
  21. Are you able to test it while its still on the intake? I have the manual that shows me how to do it
  22. I have searched and searched but found nothing with similar symptoms. When the engine is cold and I start it, the idle is low and tries to stall on me unless I keep feathering or steadily give it gas. Then if I try to drive it, its very lean, no power, and tries to stall under load. Once it is warmed up everything is fine, tons of power and idles great. Idk if its the CTS or what but I can't find anything else.
  23. Thats why I asked before wasting my money. Thanks Indiana!
  24. Oh it seemed like the canister restricted it. It would help if i replace that rubber accordion hose with hard pipe though right?
