Everything posted by neohioquest
I think I have seen that guy louswheel01 is talking about at the shootout. He runs in the 8's I believe.
Hey man. My name is Nick. I've been to the shootout the past couple years. I have a silver quest and I live a little south of Akron in Wadsworth. I may have met you there.
save this one, looks like a good start
neohioquest replied to Xtreme Industries's topic in eBay/ Craiglist notices and alerts
Someone save it!!! -
Ah yes I do remember seeing this post. Well its just odd because I was almost certiain the car is an 87. It obviously didn't run when I got it and I had no intention of getting it going. In that case these are useless to me.
No problem! Haha I hear you, totally inderstandable. I will most definately stop in when the car is running.
Ok fellas, I have a question about possible replacement injectors. The parts car I puchased a couple years ago had some work done to it previous to me buying it that the owner was telling me about. Recently I was cleaning some parts up and found the injectors that came out of that car. I looked at them and found they were both black in color. At first I thought are these 2 primairy injectors? Then I saw they each have different markings on them, One has a symbol followed by H-6 and the other also has the symbol followed by Hz-01. I will attempt to post pictures soon but figured I would just throw it out here. If anyone has any info on this before I have a chance to post pictures let me know! Thanks in advance!
It's been a while since I have been on here, it'e been a busy past year with work and I got married and all of that great stuff! It'll be one year next Saturday! Anyways enough about me and to the point. I removed the engine from the quest in November of 12' with the best intentions to freshin it up. That plan went south and I ended up with another engine so I am getting to that. Today I drove out to Niles from Akron to see Randy at Engine Machine Service and got the rest of the parts I will need to get her going again. I just wanted to say that it was a pleasure to finally meet Randy and his wife at the shop, they couldn't have been any nicer! So again, another thanks to Randy and his services speak for themself. So hopefully I can post again with good news of a running car again soon.
I had the housings off of the CHRA. Those measurements are correct. The hose size for the tube is 3in and the outlet is 2in.
Anyone else have any info or ideas here?
There doesn't appear to be a tag on the center cartrige anymore.
Okay, I have a friend that gave me a garrett turbo charger and I am trying dearly to find out what it came off of and if it could benefit me. I will start with the specifications. The turbine is a T3 housing with an a/r of .36 as far as I can tell. It is kind of hard to see. The turbine wheel is as follows. Inducer 64.4mm (2.5in) and Exducer 45.9mm (1.8in.) The compressor is a to4d I beleive and has an a/r of .50 The wheel is, Inducer 46.5mm (1.83in) Exducer 60.14mm (2.3in) I did some research as to just the size of the compressor wheel and it is the same as a 16g. I cannot figure out what this turbo is off of. I dont think it would be very efficiant on our car because of the very small turbine housing. Haha it would have extremely quick spool but be good for about 3k maybe. Anyways I have another turbo I was thinking about using to combine the compressor of this turbo with the turbine of the other one. The turbine of the other one has an a/r of .63 and the wheel measures Inducer 52.7mm and Exducer 75.4mm. Any thought on what the first turbo could be off of and also thoughts on if that would be a good option?
That is also an old tsb. Not to freak you out. I would check compression when the concern is present. Especially since you have replaced the coil and plugs multiple times. All that is left would be fuel and compression. If both of those rule out than there may be a possible signal loss to the COP. Another easy thing to do if your compression checks out would be to swap the injector with the one adjasent to it. Obviously if the misfire follows than you may have an issue there.
I found this also specific to a p0306 TSB 97-25-8 RUNS ROUGH - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTC) P0300 THROUGH P0308 MAY BE STORED IN MEMORY - VEHICLES BUILT THROUGH 11/26/97 EQUIPPED WITH 4.6L OR 5.4L ENGINE LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTC) P0300 THROUGH P0308 MAY BE STORED IN MEMORY - VEHICLES BUILT THROUGH 11/26/97 EQUIPPED WITH 4.6L OR 5.4L ENGINE ENGINE - ROLLER FINGER FOLLOWERS DISLODGE - DURING AMBIENT TEMPERTURES LESS THAN -18 DEGREES C (0 DEGREES F) - VEHICLES BUILT THROUGH 11/26/97 EQUIPPED WITH 4.6L OR 5.4L ENGINE Publication Date: DECEMBER 8, 1997 LIGHT TRUCK: 1997-1998 ECONOLINE, EXPEDITION, F-150, F-250 LD 1998 NAVIGATOR ISSUE: The roller finger followers may become dislodged and end up loose in the cylinder head during ambient temperatures of less than -18°C (0°F). This may result in damage to the camshaft, roller finger follower, valve, retainer, valve guide, etc. ACTION: Refer to the following Service Procedure for details. SERVICE PROCEDURE Check compression of all cylinders. Remove cam cover from the affected side of the engine which showed low compression readings. Look for a follower that has become dislodged and examine all components for damage (i.e., camshaft, valve, follower, etc.). If damage is found, contact the engine plant Hotline at the numbers listed in this article. If no damage is found, remove all followers from the engine (both sides) and compare to Figure 1 to determine their revision level. http://www.fordtechservice.dealerconnection.com/pubs/auxf/~WT/USENIE/1906/tb5304a.gif Figure 1 - Article 97-25-8 [*]If they are the new revision, contact the engine plant Hotline at the numbers listed in this article. If they are the old revision level, replace all followers with new level Followers (F8AZ-6564-AA). [*]Recheck compression of all cylinders to verify proper valve train operation. [*]If compression is within specifications, reinstall the cam covers and any other engine components removed. [*]If the compression is still unacceptable, contact the engine plant Hotline at the numbers listed in this article. Engine plant telephone numbers: Windsor Engine - (800) 465-4680 Romeo Engine - (800) 833-4503 PART NUMBER PART NAME F8AZ-6564-AA Roller Tip Follower OTHER APPLICABLE ARTICLES: NONE WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage And Emissions Warranty Coverage OPERATION DESCRIPTION TIME 972508A Compression Test - All Models 1.0 Hr. 972508B Replace Followers - F-Series, Expedition (4.6L MFI, 5.4L MFI) 3.8 Hrs. 972508C Replace Followers - Navigator (5.4L MFI) 3.8 Hrs. 972508D Replace Followers - Econoline (4.6L MFI) 5.6 Hrs. 972508E Replace Followers - Econoline (5.4L MFI) 5.4 Hrs. DEALER CODING BASIC PART NO. CONDITION CODE 6529 33
I'm a Ford Tech in Akron man. I have had those older 5.4 engines have fuel injector problems. I will run the year and model on my ford site since I dont have a VIN to specify the model to see if there are any TSB's. As far as I can remember I though there was some sort of message abouth the injectors. I would not beleive it would be an egr issue because it is a specfic cylinder.
T3 5-bolt wastegate adapter with wastegate.
neohioquest replied to neohioquest's topic in Items Wanted
I will send you a PM -
I know haha. I just want to explore any other option before buying one. -
Hello all, I am looking for a 5 bolt wastegate adapter so I can have an internal wastegate with the turbo I have aquired. i have seen these on e-bay with a v-band down pipe flange which is what I am looking for but anything else will do. I also can trade for any oem part needed,so let me know if any of ya'll have this and either if I have anything you need or what you would like for it. Thanks, Nick
Advice on how to deal with my mechanic....
neohioquest replied to Walker's topic in Just plain ol' B.S.
I agree with what these guys are saying. Luckily my trade and the way I make a living is working for a Ford dealership as a Technician. Also I am located in the Akron area and am more than willing to give advise on just about anything that I feel I am able to help with. I've had my Quest for about seven years now and have had a couple small issues with it. But like any other car can be fixed. Send me a message on here and I will be more than happy to help. And if you are close enough even come help ya! -
haha it sure is! I usually put around 3-4 gal in on every oil change.
All of the Super Dutys with the 6.7L have this system. You have to add up to 5 gallons of it per service interval.
Pm'd you.
I will be going for sure.
A question for those of you with porno red/maroon interior..
neohioquest replied to tankbob's topic in Just plain ol' B.S.
I have had many responses. Either dang this is 80's or I have even had a couple kick tail compliments. Mine is Maroon leather. Personally I like it,it fits the car. My parts car has a black leather interior in great shape. There may be a swap someday. -
Black Quest TSI Lancaster Ohio. Not mine. Just spreading info.
neohioquest replied to neohioquest's topic in Cars for sale
Yeah I didnt know they had them. This thing is beautiful. If I had the cash I'd buy it haha
