RUBEN88TSI
Everything posted by RUBEN88TSI
  1. Man. Yeah, I recognize them too. I know him from waiting on something he sold me this past Feb. It's terrible to know that he's letting go of her.
  2. Hey how's it going Guyz. Here's a lil more info for ya (applies to the 88 and 89 but not sure if before...): At the ETACS under your drivers seat: Factory Alarm Disarm - brown Hood Pin - white/green Trunk Hatch Pin - red/white *all negative triggers... *possible to grab Hood Pin and Factory Alarm Disarm behind drivers kick panel... *Hood Pin may set off false alarms if bad/going bad (either check your alarms diagnostics to confirm if it's that trigger or dis connect that trigger and arm your alarm again to see if it'll go off on ya). Yes you can tap into the factory locks Man! The panel above the drivers kick w/ the relays on it: Lock - red/blue/silver Unlock - green/blue or red/green *all negative triggers... Hope this lil bit of information helps Man. Since I've had my 88 TSi since Dec. last year/2010 I've had to deal w/ more than enough electrical gremlins. The info on the all Grounding Issues, Headlight/Switch Issues, Diagnostic Codes/LED Set Up, TPS/ISC Reset, Wiring Issues w/ the CTS/Water Temp Gauge/A/C Compressor Overheat Shutdown (FINALLY, better gas mileage!), and then some, has been extremely helpful thanks to All You Guys on here! Still more work to do... Later Guyz.
  3. Hey, how are you man. I'm interested in the: front drivers fender, rear hatch (are the 2 tabs for the defroster located at the bottom of the glass leading behind that bottom panel still intact?), the front header panel (between the grille and hood), and the rear tail lights (if not visibly cracked). What would pricing be for each piece to 90026? Thanks man.
  4. Hi, how's it going. I'm interested in one of your average or better 7" wheels. Do you still have any available? If so, then please let me know how much shipping is for 90026. Thanks man. -Ruben
  5. No problem Steve. Thank you man. Hey Corey, what's up man. Were you able to find out a price for 90026? When you're free, let me know man. Thank you.
  6. How are you man. Please let me know much for 90026 if STEVESQUEST doesn't wanna scoop it up, alright? Thanks man.
