Mr._Pop-ups
Everything posted by Mr._Pop-ups
  1. No, the 2G BOV is plastic, and weak which is why it leaks boost. It leaks at the stock 12psi, which is why the first thing you do on a 2G is install an upper IC pipe and 1G metal BOV and then a boost controller to keep the spikes down now that everything is sealed up.
  2. If its a standard Mitsu pump, you can either use stock DSM pump, RX-7 TT pump, Supra TT Pump, or an in tank WalBro. Stock DSM pump: 100lph@37ish, $free-100 RX-7 TT: 210 lph@43, $75-125 Supra TT: 295lph@43, <$200 WalBro: 195 or 255@50ish in tank, $100-150 http://www.roadraceengineering.com/fuelpumptechtip.htm http://www.roadraceengineering.com/fuelpumpflowrates.htm
  3. 'Scuse me? How can you figure? With a bleeder valve (or MBC) you can pump the boost on a 14b to at least 20psi with just an upgraded fuel pump. That will give you close to 200 to the ground. Whats that gonna cost you in a Quest that weighs about the same? Ive driven a good running stock Quest and no way is it faster than my AWD when it was stock. I have a 7psi stock turbo AWD sitting in the drivway right now thatll take on even a mildly boosted Quest with no problem. And AWDs are geared lower so top end suffers against say a FWD.
  4. Stock the crank is Nitrite hardened. If you grind the crank any, it loses it. Goodluck on finding someone let alone a cheap someone to do it for you.
  5. I dont understand why you guys think a 3" exhaust = lag? The faster you can get the exhaust gasses out of the turbo the better. When i put a 3" on my Talon with the stock 14b turbo, i GAINED 2 psi and the boost came on about 500 rpm LESS. To test spool, be in 4th or 5th gear at about 2000rpm, then floor it and watch at what RPM you hit full boost. If youre talking about off idle response, it might seem like its laggy because the boost start building sooner, but you dont feel the full effect till higher up. Like with a larger turbo, you think youre not making the power, because it comes on in a more linear fashion, not like WHAM and wow.
