Boosted_Widebody
Everything posted by Boosted_Widebody
I need a radiator in good shape, prefer an aftermarket but not required. Need the main fan with the sensor and wires. "the fan on pass. side of radiator" I cant find anywhere around nashville that has the fan, no junkyards within a 100 miles have a starquest. Only found 1 shop that can get me an oem replacement and thats the dealer...but its 185.00 for oe.
Vaccum nightmare! please help.
Boosted_Widebody replied to Boosted_Widebody's topic in Virtual Mechanic
i have 2 other cars but they have the vacuum delete on it by the previous owners when i bought em. and this one "my 89 with 131k miles" had a bunch of stuff mising along with a blown head gasket, missing nuts and bolts, missing both injectors and etc. Today I did everything to the best of my ability going off starquest faq's and SHELBY and BC_99's advice on the wastegate and air can lid. Something still isnt right, I know the car is in time. So im going to give a run-down of the symptoms I had today on its first run. BTW, I have emissions testing here so I cant do a vaccum delete on this one as it will be daily driven, hopefully soon....though that would make everything alot easier and can copy the set-up on my other cars. Okay, starts up fine, idles at 1800 or so rpm. When I remove the hose on the vac advance it drops to 1k with a rough idle...so im assuming thats working right. If i keep the vac advance hooked up and move the distributor untill the idle is at 1k or so rpm, the throttle response is bad and tries to backfire through the intake when revving up. So for now im dealing with the high idle since its smooth though high, and has a quick throttle response and smooth revv while in neutral. Now, the driving symptoms. Its smooth if your giving it about half throttle. When you put it to the floor it becomes rough, though it will climb to about 6k..it just seems like it doesnt have the smoothness and power it should. I hooked the wastegate up like some member had told me, one plugged, one open to air, and one to the sensor which is the 10lb diaphram. But im running easily 20psi. Also while driving if you barely give it gas as if your trying to maintain a speed it sputters and such. When you put the clutch in to come to a stop, the idle goes to about 3k for a min. and the drops down and either acts like its going ot die "500-600rpm" or actually dies. Now im sure most of this is a vacuum problem. But what type of vacuum problem and where its at im not sure. I have 3 diff types of diagrams ive found off this site and printed step by step instructions by members. Another thing im 100% positive of is 1. (the main line that runs from all the cans and fittings on the pasenger side, across the firewall, and then over to the throttle body area was cut by the previous owner. I have no idea where to hook that up to, so right now there is zero vaccum going to that side of the car and anything running off that line.) 2. ( My wastegate is a 3 port. The vacuum line on the air can lid according to the stock vac diagram on the hood is going into the farthest right port on the electronic solenoid on the air can lid. the port to the left of that one is plugged, since i was told to leave one port open and one plugged on the wastegate i dont have a line to hook to it so thats what i did. the the port coming off the side is the one running to the wastegate. okay, now the 3-ports on the wastegate: there are 2 on the left..pointing left torward the fender, and one at the top pointing up. the one at the top is plugged, the firt one closest to the radiator is connected to the left side of the sensor on the air can lid, and the port closest to the firewall on the left side of the wastegate is open. But im running 20psi + on an aftermarket gauge and i know that is wayy to much for a TBI. Though i didnt hit fuel cut? so im confused on why.) 3. ( The 3 ports on the throttle body, the port farthest back is running to my vac advance on the distributor and thats it. the middle port is plugged. And the last port closest to the radiator is going to my boost gauge and only that.) 4. ( The THERMO Valve has been removed and hole plugged. The vac lines running around the EGR and 2 sensors on throttle body are all hooked up with no open ends.) 5. ( under the air can there is a plastic canister with 2 vac lines coming off of it, when i bought the car those 2 were running to the wastegate? now they are hooked to nothing since nothing been mentinoed about those going to the wastegate i dunno where else they would go.) 6. ( Im using the stock intercooler piping...on the hard pipe that goes over the valve cover theres a nipple that was plugged when i bought the car. Its still plugged, i dont know what goes to it.) 7. ( The accordian hose...there are 2 holes on the right side of it. Both ports had plugs on them when i bought the car. The bottom BIG port had nothing running to it, and is open to sucking in air...so since i dont know what would go to that its still sucking in air which isnt good since its after the maf sensor. Also, I dont have the oem metal can that holds the filter, so im not sure if something is needed off of that. Needless to say since i dont have that, i also dont have a filter right now since i cant find a filter that will cover the massive and odd shaped maf.) I tried to use my other car for an example of how things should go, but since it has the vac delete and i dont run it for testing i cant use it. I cant go by how the air can lid or accordian hose is on it because the previous owner made a custom intake pipe in place of the accordian hose and installed a K&N filter to the lid without using the can part. There are no nipple on the aftermarket intercooler piping on it, nor on the turbo inlet pipe so im lost. I dont know of anyone thats owned one or owns one around here, auto part stores are lost and cant help me, and only one shop is willing to work on my car and they have had my car for 2 months trying to figure it out....so i drove it home and now on my own with this. Please help. -
Are there any starquest owner's near here? I havent seen any starquests in the middle tennessee area and was curious. Not only wondering if im the only one, but I sure could use some help with putting my current one back the way its supposed to be. If there is anyone close by...or even torwards Franklin, KY- Portland, TN - Gallatin, TN - or Mt.juliet/Hermitage, TN....call or text me @ 615-668-6738 -joe
yeah i was going to take a look at everything in there this weekend when im off...but today i decided to look a the online manuals we ue at the dealership, and i found buttloads of useful repair info i havent been able to find on here or the internet. so..im going to figure out how you post in here or in the faqs and list vids and pics of complete diagrams, schematics, and how to's. -
thanks shelby...and yeah i do have emissions here i figured everything out earlier today...another quest on the road. and i ssure you, this among many many topic are saved in my favorites for down the road. -
i dont mind constructive critizum. as an 8 yr member of the armed forces and 3 time oif/oef veteran i assure you i can handle it. there is a difference in helping someone...in your case, you still have yet to give a helping hand on the topic. and number 2, emissions arent the same on all cars. thats why there is obd-0, obd-1, obd-2 and so on. second, a turbocharged or supercharged vehicle creates more vacuum than an n/a vehicle. that vacuum needs to be routed correctly so the added cfm from the forced induction will work properly along with the combustion process. As my original post stated, i not only wanted to know what i didnt need in the EMISSISIONS...along with what i may have WRONG or may be MISSING on the REQUIRED vacuum ports to run this particular vehicles turbo, injection, MAF, and other such needed things properly. YES there is diagrams in the FAQ's, yet i also stated after searching for hrs i couldnt find the diagram I had once found before. None the less, if you look at the diagrams...it doesnt show you where the wategate lines go, and what and where all the lines go for the air can and lid. Pretty much the most important thing to have hooked up on this OBD-1 vehicle. But thanks for your input and your very helpful answers so far. As i may not have 30k post and read 500k posts...I do spend my time helping others or just not replying if i dont have the answers on other sites such as NICO.com, Turbododge.com, D-series.org, and others im a long time member of. Everybody else...thanks for your help and guidance on where to look. And to everyone else that looked at this thread "as i see theres alot more views than posts" thanks for keeping things to yourself. EDIT: Also...just to see why people like me ask questions like these, try using our search feature on here or google. Type in thermo valve, or what is a thermo valve and see what comes up. -
Lil bit of custom work..
Boosted_Widebody replied to Boosted_Widebody's topic in Body and interior Mods
yeah, but a single 3" straight tip on the front passenger fender even with the side-skirt. pretty much an open downpipe, but since we have emissions, a "test pipe" welded in somewhere.... the more ive looked at it though, im thinking im going to have to go under the frame where the bend is still high for clearence on the road. i dont think its going to look as good this way so the plan might go out the window. im going to tac weld a small piece of pipe to see what it would look like just coming out under the fender. if it doesnt seem to look well, then i might have to steal your look lol. -
So after reading these diagrams, im pretty much set. but two more questions. 1. the sensor that had 2 vacuum lines coming off of it on the intake manifold under the thermostat housing broke on me. I couldnt find out what it was so i just plugged the hole. Once reading these diagrams Ive discovered its called a (thermo Valve). Is it okay if I leave it plugged, or do i need the thermo valve? I looked through autozone, advance, o'reileys parts thing and couldnt find anything but the temp sensor. So if i do need this, anyone know a good place to locate it or a part number to order through a dealer? 2. When i bought the car the thermostat housing was cracked and mission a sensor that screws into the housing itself. So Once i finally located another housing, i once again went to the autopart stores to find out what sensor it was. There again all they could provide me with was a temp sensor...and this one has a much smaller opening then a temp sensor, and the fact i have one mounted already. So i have plugged this hole as well. Is it okay to leave this one plugged up as well? if not what is this and a location/part number to get it as well. Im assuming its only a one prong male end on the other side since the only wire i have not plugged to something is a single plug female. sorry, and thanks. -joe -
thanks, yeah that helped ALOT. I found that late last year an printed it...but lost it after i came home from the deployment. really appreciate it! -joe -
and yes SHELBY, as you are correct about there being more lines on many other cars....it generally easier to find someone who knows about it locally to help you, find a nice repair manual in a local autozone or whatever... Seeing as these cars are owned by the few and the proud. And the fact its not an N/A car...certain things need to be hooked up in the correct place for it to function. So even though youve been on the site for years and have 500k posts....if your just gonna knock on people needing help and not give advice. Try and keep your post count up somewhere else. Even as a newbie to the site, not to turbo dodge, starquest, lebaron gtc's, and many other late 80 and early 90's cars...I was able to notice that this a forum to help people on stock drivetrain and problems...not to bash people for using it with its intended purpose created by the admins. also, hondas have half the hoses these do. mainly because they arent a forced induction engine needing the extra vacuum. I know this because im a mechanic at a honda dealership, let alone every one of my friends own one if they arent driving an evo or sti. -
well i wanted to keep abs, everything else could go. yeah i have the 3 port wastegate, i kinda assumed the 2 side ports went to the boost sensor on the lid. the top port i was really unsure about. And i thought i had the line to the throttle body plate from valve cover right, thanks for reassuring me of that. Other than that i have everything correct on the firewall. and i believe everything is right on the throttle body with the 3 ports, egr, etc. i dont have an egr block off plate, so i assumed i needed to have vacuum running to that for the time being. I was just worried i had things (mainly the wastegate and maf lid) wrong and scared it would mess things up. So essentially, if i have these lines hooked up right, the car should be fine. -Boost sensor on the air can lid. Not using the can, just the lid and poor designed maf lol, and plug up the hole on the bottom of the accordian hose, and the 2 ports on the side of it. -the 3 ports are ran correctly from the throttle body, egr ran right, and nipple on intake manifold under throttle body plate ran to valve cover (front) and everything else on the intake manifold/throttle body. -and still confused...but if not needed either plug it or run it to (where?)...the top nipple on the 3port wastegate. -and lastely the nipples broke off, so i just plugged the hole....but on the intake manifold right under the thermostat housing there was a sensor type piece that had two vacuum ports on it...i was told it was for the smog system. if im wrong please let me know and what it is so i could try and find that part. nobody around here knows anything about theses cars so im usually only relying on past cars, or starquest searching for answers. otherwise, with the above the way it is...nothing else is needed and can be plugged off and the car run fine i assume? thanks for the help bc_99, thought you might been mad at me for our past problem. I still apologize... -
I also have about 10ft of new hose....so i have plenty to reroute, if....i knew where one end starts and where the other ends. -
I really aplogize in advance, but ive been searching for hours and getting aggravated. I have a repair manual but its not helping me too well. Im needing a diagram of what i can and cant delete when it comes to vacuum lines. The areas I really need help in is the stock wastegate, the air can lid, and the throttle body. Then, im confused on where the hose goes on the front of the valve cover? And what and where does the line go from the big hole on the bottom of the stock accordian hose. The 2 holes on the side are blocked off already. And lastely, I dont need the metal can, just the lid right. Im assuming all that really is for is the smog system? The car is an 89 conquest tsi. Im wanting to delete as much of this vaccum nightmare as possible, as so far havent found anything really explaining, or a diagram showing, what is what...and what is needed and what is not. Please help....im literally on my knees begging while pulling all my hair out. ...sorta like this the past couple days over this mess. like i said, im begging for help.
yeah i thought about that. fortunately the one im doing it to is a garaged car brought out on the occasional weekend for a car show or a litlle track time. i like being the only space ship around here lol. thanks for the comments...i really hope it turns out as cool as i vision it. -
I hate to sound like a little school girl, but im pretty excited about a project im starting mid next week. One, im custom fabricating a side exit exhaust. My plan as of now, and with the way its currently layed out i believe its going to look and sound amazing. But its not going to be an average side exit by the rear tire....Im planning on a pasenger fender exit, but torward the lower part of it to cut back on future exhuast coloring or heat damage. 2nd, I seen a couple hondas running around with those front mount cold air intakes...they look similar to a small intercooler and apparently work well. so my plan so far is to buy the kit, and customixe that fmic looking air filter either into the passger side front lip beside the intercooler...or do something in the engine bay and flush it with the hood when it closes, and of course end up with some body work on the hood to make it functional. lucklily if I go the hood route, a friend hooked me up with a complete set of 280z oem hood scoops, though i dont think they will be wide enough, they might look cool and be functional. if not, well ill figure out something along the way. ill post pics on photobucket when i get far enough in the project this week or next weekend and it starts to look like something. the project is on my red 89 quest tsi btw.
sure does look alot better than mosul, iraq. you guys have it made in those spacious looking chu's with the big beds lol. stay safe. ohh, and out internet was 130 a month for 256kb hardwire. about a month before we left 03-2010...they put in wireless for 256 @ 90 a month. it sucked...when we didnt have a blackout, the internet only worked half the time anyways.
89 quest is on the road. Needing bell housing bolts to finish my other 89 quest.
I bought another conquest, needs (manual) trans replaced and clutch. So when I began to drop it I noticed 4 of the bell housing bolts were missing, 1 of which holds on the starter. Ive looked at several auto part stores, hardware stores, and online oem Chrysler or Mitsubishi sites and cant find the bolts im needing. The ones I find are either a 1/4 in. short, not hardened, or flanged. anyone know a site or place I could get them and a part number for them as well? Its the only thing holding me up from having my 3rd starquest "in my current possesion" on the road. Pleeeeaaasse help. -joe.
would you happen to be able to get rid of a set of bell housing bolts? pm me if you can.. thanks, joe
what size slicks are people using
Boosted_Widebody replied to skillz's topic in Advanced Virtual Mechanic
Nitto has some really nice drag radials out right now for a decent price. some of my buddies are using them. i dont have any, but if your not making a whole bunch of power like me "maybe 250ish" on stock suspension....ive had good e/t's on regular summer tires. i like the goodyear gs-ds3..they are pretty soft for an everyday tire and get pretty sticky with a small burnout. -
89 dodge daytona es. 2.5 Sohc mpi turbo non-intercooled, 5-speed getrag transmission. light gray cloth seats, drak gray dash. no rips, tears, cracks at all. carpet a little worn, but would look nice with a good shampoo. has orginal mopar/infinity stereo with equalizer radio, all electric, boost guage and others minus speedo worked fine, a/c worked fine all before parked in 2004. the speedometer started acting up in around 99, sometimes it worked...sometimes it didnt. i drove the car for maybe 2 years, only one long trip "565 miles" otherwise a couple miles. parked in 2004 due to a rod knocking and the speedometer reads 94k. im assuming no more than 110k on body. Car has been sitting for about 6 yrs, strting to develope minor surface rust around the sunroof. Windshield has a small crack in it. water never got in the car, all seals are in good shape. Brakes are rusted up, tires are starting to dry-rot even though they only have about 1k miles on em, they do hold air. the good: -brand new long block motor from grooms engines. never been started or put in, but has minor surface rust on cam lobes from sitting "covered" without the valve cover for 3 yrs in my shop. -brand new radiator -brand new shocks, struts, ball-joints -brand new oil pan "stock one has a hole..hince the reason for rod knock in old motor" -brand new oil filter, plugs, gasket kit -comes with complete manifolds, pulleys, altenator, a/c compressor, starter etc. -comes with stock oem mitsubishi t1 turbo...has about 40k on it with no shaflt play or thrust wear -since the car is non-intercooler, im throwing in an oem starion fmic in good shape -brand new oem clutch kit -new thermostat the bad: -needs passenger side axle -needs emergency brake cable -needs rotors and pads -prolly needs new tires, though they dont look that bad to me -doesnt come with old motor, engine and everything has been pulled so ready for everything to go back in -carpet needs cleaning...i guess from summer and winter wether changes mositure damaged the color of the carpet. -windshield has crack in it, but not one that prevents you from driving it. just against the law here to havea cracked window. -muffler rusted out, so from rear axle back it needs exhaust work. stock downpipe back is 2.5" -may be missing some nuts and bolts to put it back together, i started to fix it about 3 years ago but quit and started playing with the starquests again...so in those 3 yrs my dad has moved the car from the driveway to the field, and then back a week ago. so im sure some had fallen when it was moved. i put what i found in a bag. i cant figure out how to downsize pics to put em up on here, so unfortunately all i can do is do a pic message to your phone, or email some to you. 900.00 firm. 615-668-6738 is my cell. im located near nashville, tn.
i know this probably sounds stupid...but where is the plunger located at? the repair manual isnt showing a very accurate picture of its location.
i dont have smog, but i do have marta emissions tests...if that the same thing? otherwise i could just plug it? thanks for the help.
I let my friend borrow my car, and apparently the fans stopped working...and the idiot blew my head gasket the other day. The fans arent my concern. Once the head is on and I have it torqued down, I cant seem to get the timing sprocket back on the camshaft. Any tricks/tips without having to take the chain off? and my other question. there was a switch that on one end has a probe like end to it that mounts on the intake manifold close to the thermostat housing, and on the other end has 2 vaccum ports that runs to the throttle body. please tell me what this is. I dont know how to make pics small enough to upload on here..if you dont know what im talking about please shoot me a pm with cell number or email and ill senda pic. thanks, joe.
