Everything posted by ShkInBk
I still need a quote for the above.
Thanks everyone. It appears that Vegas is my best bet since it is only a 5 hour drive and gives me an excuse to go to Vegas;) However, I will be buying a house soon so I'll probably put this project off until next year. When I'm ready I'll look you up Sotty.
I'm in no hurry - the zip code is 85120.
Sorry for the slow reply - I just moved so I have a lot going on. Could you get me a ballpark shipping quote? Thanks!
87-89 5-Speed Transmission in Arizona
I need a manual tranny, clutch, and flywheel to match. Can you tell me how much shipped to 85120?
I could use the transmission - how much shipped to 85120?
87 Black Starion in Apache Junction, Arizona $2500 obo
ShkInBk replied to ShkInBk's topic in Cars for sale
Nevermind...I put the driveshaft back in last night and it won't go into gear - I think the tranny blew 1st and that's what caused the stress on the drive shaft so now it will sit indefinitely until I have money to get the tranny rebuilt. -
Bump. I'm getting the drive shaft balanced before putting it back in with two new u-joints. I'll go $2000 firm. -
Paypal Sent!
Paypal please? Thanks, Mike
This is as much a feeler as anything. I really don't want to sell but I'm in a financial hole. I'm looking for $2500 obo - I have over $5000 in parts invested (not to mention labor). 1987 Mitsubishi Starion 123K miles - original engine - rebuilt head with jet valve elimination kit - stock turbo - stock intercooler - almost everything else new/upgraded;) Here is the bad: The U joint just failed today so I had to have it towed back to my mom's house in Apache Junction. I just ordered 2 replacement U-Joints and will have my cousin help me replace them (he is a certified Mitsubishi mechanic and has done all the work on this car). NO A/C - I had to remove the A/C to fit the huge *DM Radiator and Flex-a-lite 420 - Universal Dual Electric Fans (made for Eclipse). This setup keeps the car cool at all speeds but it would rub against the AC pulley so the pulley had to go. Windshield Wipers do not work - I have a parts car that may have good motors. Driver's Side Auto Seat Belt does not work - the lap belt is fine but the shoulder harness is stuck all the way back. I just wiggle under it. It can easily be mounted to the door if you prefer. Antenna is broken off - I replaced with a powered windshield mounted antenna that works fine. Driver's Side Rear Fender is in bad shape - the previous owner had a blow out and damaged the fender badly - I had my cousin pull it out but still looks bad. Here is a list from a spreadsheet I've maintained keeping track of all the parts I've purchased (everything has been installed except the stainless steel brake lines, 52mm throttle body, new fuel injectors, and ported intake manifold): Rebuilt Head with Jet Valve Elimination StarQuestClub $250.00 1987 CONQUEST Body, Chassis, and Electrical Shop Service Repair Manual Amazon.com $74.80 1988 Starion ECU StarQuestClub $65.00 NGK ME51 Plug Wires Amazon.com $18.67 NGK BPR7ES .35 Gapped Spark Plugs Amazon.com $13.40 Mitsubishi Starion Conquest 100 Amp Alternator ebay: starters-alternators $84.95 Gates V-Belt: High Capacity (Standard); Water Pump And Alternator 7380 Checker Auto $13.99 Airtex Distributor Cap and Rotor Kit 3D1068 Rock Auto $14.43 Fram Fuel Filter G6495 Rock Auto $11.50 Gates V-Belt: High Capacity (Standard); Power Steering 9295 Rock Auto $8.50 Gates V-Belt: High Capacity (Standard); Air Conditioning 9540 Rock Auto $12.64 STARION EGR BLOCK OFF PLATE CONQUEST Ebay: 101Propose $13.99 Anchor Motor Mount (Front & Rear) 8110 Amazon $31.58 Anchor Transmission Mount 2730 Amazon $10.78 GP Throttle body rebuild kit- includes injector seals www.enginemachineservice.com $29.99 Silicone Vacuum Line Replacement Kit (Blue) StarQuestClub $28.00 *DM 2.5" Aluminized Downpipe www.*DM.com $85.00 2-1/2 inch In/Out No Air 53000 Series Magnaflow Catalytic Converter CARK53006 http://www.fle-online.com/ $63.27 4" N1 Exhaust Burn Muffler Ebay: ixtab_imports $32.99 Cosmo Air Intake Filter Adapter Kit www.cosmoracing.com $70.50 AHP 3" to 3" Coupler, 2" to 3" Reducer, and 4 Clamps www.siliconeintakes.com $27.38 *DM 3" AHP with 2 ports *DM $39.00 Custom 2.5" Exhaust Piping and Labor Mad Hatter Muffler $250.00 *DM Aluminum Radiator and Hose Clamps www.*DM.com $335.00 *DM Upper and Lower Silicone radiator hoses www.*DM.com $85.00 Cardone Select Water Pump 55-33129 Rock Auto $28.79 Stant 180 Degree Thermostat: SuperStat 65868 Rock Auto $5.89 *DM Silicone Heater Hoses *DM $69.00 Flex-a-lite 420 - Flex-a-lite S-Blade Low Profile Universal Dual Electric Fans JEGS.com $334.97 TurboXS ROFL BOV StarQuestClub $50.00 *DM 2.25" OVCP Steel Hard Pipe *DM $65.00 MK1 Starion Upper Hard Pipe Ebay: 101Propose $59.99 Silicone Couplers and Steel Clamps www.siliconeintakes.com $26.38 Steel Braided Water Pump to Turbo Coolant Line lower_shores_performance $39.99 Steel Braided Thermostat to Turbo Coolant Line lower_shores_performance $39.99 Steel Braided Oil Drain Back Line lower_shores_performance $25.99 Steel Braided Oil Feed Line lower_shores_performance $50.00 Turbo Timer Kit with Harness Ebay: 101Propose $49.99 Wagner Brake Pad ThermoQuiet Brake Pads: Front MX258 Rock Auto $10.38 Wagner Brake Pad ThermoQuiet Brake Pads: Rear PD144 Rock Auto $18.45 MITS STARION 2.6 88 F+R D/S Brake Rotors ebay: OCAutosports $147.00 BOSS HUB STEERING WHEEL ADAPTOR MITSUBISHI STARION Ebay: sonicmotor2000 $24.95 MOOKEEH MK1 S2 STEERING WHEEL Ebay: 101Propose $19.99 Blue Digital LED Boost & Exhaust Gas Temperature Combo Gauge www.glowshiftdirect.com $139.99 Blue Digital LED Water Temperature Gauge www.glowshiftdirect.com $49.99 Water Temperature Sensor Hose Adapter www.glowshiftdirect.com $14.99 86-89 STARION CONQUEST DUAL GAUGE POD (2-1/16" GAUGES ) Ebay: 101Propose $39.99 Fuzion Touring (H- or V-Speed Rated) Tires - 40K/5yr Warranty Tire Rack $366.54 STAINLESS STEEL BRAIDED TEFLON BRAKE LINES (Blue) 3SX Performance $106.95 NEW Fuel Injectors lower_shores_performance $168.00 52mm Throttle Body and Ported/Bored Intake Manifold StarQuestClub $215.00 Clarion CZ401 CD Receiver Crutchfield $109.99 Kicker KS525 5-1/4" 2-way car speakers Crutchfield $67.49 Kicker KS65 6 3/4" 2-way car speakers Crutchfield $89.00 Stereo Adapters for Head Unit Crutchfield $23.00 Kenwood KAC-7005PS 5-Channel Car Amplifier www.hookedontronics.com $209.99 Tinted Windows Quality Bumper $210.00 Here it is being towed today after my U-Joint failed;( http://i1350.photobucket.com/albums/p762/mcrisfield/20130422_111150_zpsba5312fc.jpg http://i1350.photobucket.com/albums/p762/mcrisfield/20130422_111126_zpse78fceff.jpg http://i1350.photobucket.com/albums/p762/mcrisfield/20130422_111137_zps94340eab.jpg http://i1350.photobucket.com/albums/p762/mcrisfield/20130422_111115_zps0d4e6bd5.jpg
Good seller. He shipped the product very quickly and did a good job packing it.
Is this turbo bolt on with a stock exhaust housing? External/Internal wastegate? Stock intercooler pipe locations or will i need to fab something? I've been burned on 2 used turbos so I'm very hesitant to try a 3rd time but I know you have a good reputation and can be trusted;)
I just spoke with Michael at Forced Performance and they have brand new 14Gs in stock at $1150 (18G will run about $1350 but they are out of stock). However, they can rebuild your 12a into a 16G for $595-695 if your exhaust housing is in good shape.
I have a TBI car and I've done many upgrades (full 2.5" exhaust with *DM catless downpipe, Cosmo open air intake, OVCP, etc.). Now it's time to upgrade my turbo and Forced Performance offers brand new 14G and 18G turbos for similar prices. I would love the horsepower of an 18G but I don't want to sacrifice my 0-60mph time for freeway power. I almost always shut it down at 80mph so I want something that will spool fast and have me winning off the line not trying to reel them in before we hit freeway speeds. Can I do this with an 18G at 15psi on pump gas or will I be better off with a 14G? Will the 14G get me into the 13 sec quarter mile territory while staying TBI? Thanks for the info! Mike
I bought a "freshly rebuilt 14G" that has more play than my 100K 12A turbo. He also asked "do you want an exhaust housing? its not necessary save some shipping cost", so I said no but when my mechanic just opened the box to install the turbo it was dirty as hell, the intake side has a ton of play, and the exhaust side has bent fins....2nd turbo in a row I've been burnt on in the last six months. I'm not buying anything but brand new from Forced Performance or Turbochargers.com after these fiascos.
ForeverZero burned me for $350 on a rebuilt 16G that required custom intercooler piping to mount (not mentioned in sale), came with a leaky stainless steel line (I replaced with all new stainless lines), then the turbo leaked a little oil at first but I couldn't tell that was where the leak was coming from until 3 weeks later when it started spewing oil.
Louvers, Front Air Dam/Lower Bumpers, 2 Epsilon/Southern Ways wheels
ShkInBk replied to Tubbs's topic in Parts for sale
PM Sent! -
I'm interested in the turbo. Who built it and do you have a receipt for the build? Is it completely bolt-on for my 87 Starion? Thanks! Mike
87-88 Parts Stock and Aftermarket - Free Baltimore Delivery!
ShkInBk replied to DJpowerHaus's topic in Parts for sale
Is the turbo completely bolt-on, no mods needed to my 87 Starion? If so, how many miles? Thanks, Mike -
I need the fuel neck shipped to 85209. Thanks! Mike
Here are some pics of a turbo I got in trade from someone next to a stock 12A. Let me know what you think it is. http://img14.imageshack.us/img14/7503/1001871o.jpghttp://img38.imageshack.us/img38/9418/1001868r.jpg
