Everything posted by trini2dbone
yes exactly that!
i hust relized that it only does it when the car is cold... maybe that helps
what is a vaccum advance
i took my cat out
cause it dosnt fall on its face it juss stays strong at 4k
i changed tho's and its dosnt cut fuel i dont think...??
my car wont drive past 4000rpm, no matter if i keep holding it or not. it is coming on boost but just wont climb past 4000rpm, any ideas or help?
i run quaker state 20/50
the green is the secondary
what ecu do you have?? my car used to do that until i put the 89 ecu bcus they dont have the boost fuel cutt!
and make sure the pulgs are goin to the right injector, if i were you is give it a couple cranks and then unplug both chlips and hold the throttle to the floor and see if it cranks and runs until the fuel is burned
check your secondary injector clip and harness
first i thought my IC pipe poped off. that wasnt it, then i put a noid light on my secondary injector to see if it was getting brighter than it should and staying powerd on, which it was so i moved and taped the harness, that didnt fix it, so i unpluged my secondary and the catr drove good up to about 3200rpm bcause of course it was lacking fuel so im starting to think it is my secondary like mistapickles said. funny thing about it is in reverse full throttle it wont do it and reving up it wont. but once in 1st-5th it does it..... any1!!!???
Last night I'm driving home and my car was running perfect then I come to a stop light and try to take off, the ccar would bogg down an and almost shut off. I had to ease off and keep the car under 2000rpms or it would hesitate and jump. Please anybody!? Ideas??
im in Fayetteville, NC 28303
id be down!
i took both injectors out and now i 4got which goes where??? please help asap
which hoses would i replace vbrad511??
what about the brake booster hose?? my car is an 87
hurry lol
that is what i first thought, but it is BOTH rears that wont turn once i push the brake and release the pedal. the calipers turn in nice and smooth, i cleaned and re-greased my sliders, and even bled my system and took my E-brake cables off. so the only thing else i think it could b is the ABS modulator. ANY1!!??
my rear brakes keep locking up and i want to kno how you delete the ABS unit?? please help ASAP
