paveln
paveln's Achievements
Do you have: 1. TPS 2. tube between air filter and turbo? 3. brackets for connectors in engine compartment? (O2 sensor, knock sensor, resistors for injectors) 4. bracket for turbo water outlet tube 5. turbo oil inlet tube. 6. instrument panel 7. wiring harness (complete for whole car). I will send you detail description later. Thank you. Please pm me. Pavel
Hi, I need small parts, such as 1. turbo oil pipe (inlet) 2. hose between air filter and turbo 3. brackets for a. turbo water cooling pipe b. connector of oxygen sensor c. connector of injector resistors d. connector of detonation sensor I can send you pictures from manual which parts I mean in case there is anything unclear. Please pm me. Thank you. Pavel
all but the engine harness has los priority as this is the only one I already have (bought it with the engine). I do need the other part of the front harness connecting lights, A/C, horn etc. Thank you. Pavel
Hi, I am looking for 2 connectors (both parts male and female) for the ECU. They are labeled B-36 and B-37 (page 14-43 Fuel System Manual). Most likely I need to take the males from old ECU (does not have to be working) and female from the harness. Please email me at pavel@ime.a-star.edu.sg Thank you. Pavel P.S. I will buy as many as possible.
I do not have it at all, buiyng part next week and after that I will try to make it work :-)
Where can I find the cruise control manual for Starion/COnquest 1987/1989? It should be part of the "fuel system" section of the manual starting page 83 onwards but it is not there. Thank you. Pavel
I need practically complete wire harnesses plus small parts such as relays, fuses and switches. PLease send me pm. Thank you. Pavel
Looking for complete wiring for the Conquest 87, 88 or 89. Plus some small parts such as relays, fuses etc. Please send me pm in case you have it.
send me pm or an email to pavel@ime.a-star.edu.sg
I getting understand it a bit: both ports on chamber 1 are the same 1. one port at chamber 1 is connected to air behind the intercooler 2. the other port at chamber 1 is connected to the waste gate solenoid valve 3. port at chamber 2 is connected to the waste gate solenoid valve On my aircan's lid is not a sensor, but a waste gate solenoid valve controlled from electronic spark control igniter.
Anybody has a diagram of 3 ports waste gate actuator? Also how the 3 port differs from single port? Please do not tell me "just to block off one port" or "3 port has two ports extra compare to the single port" :-). Thank you a lot. Pavel
Anybody has the page 36/37 from the service manual Conquest 88, electrical, vol. 2?. It is missing in the pdf file posted at http://www.starquestgarage.com/ is incomplete. Thank you. Paevel
How much are you asking for the throttle body and tubes shown on the picture? Please send me PM. Pavel
40 + shipping. Do you also have tube connecting heater and the pump? And TPS sensor? Thank you. Pavel. Please send me PM.
Can I have TPS sensor or whole throttle body with TPS sensor? Thank you. Please send me PM. PAvel
