Everything posted by kf4eok
MAF Translator Gen II install on a 89 Conquest TSI
kf4eok replied to kf4eok's topic in Advanced Virtual Mechanic
If you notice I did not use (did not hook up to ECU) the grey and brown wire from the Gen II. I did however hooked up a BARO. Sensor (I used a Toyota vapor sensor) back to the ECU so that the original ECU would do its normal calculations with the Baro. Input. As for the IAT sensor I did use a GM open air IAT sensor and wired it to the orignal input to the ECU so that the Original ECU can do its original calculations with the original IAT input. The Gen II takes the reading from the GM MAF sensor and converts (translates) it to (in our case) DSM signal so that the orignal ECU sees a signal that looks like the original MAF signal.Whith that being said, the original Baro sensor was built into the original MAF sensor and it was installed WHERE? inside of the air filter. I could be wrong on this but I do not think so, the barometer reads atmospheric pressure pretty accuracy right. Well what happens inside of the air filter when you start up the airflow through the filter, the pressure will drop inside the air filter and the sensor will read a inaccurate reading, even worse when the air filter is dirty. I will have to say that the original Baro. should have never been located there. Yes there might be slight differences in manufactures sensor readings but I do not think that it makes much difference on these old ECU in our cars. How did the ECU comspate for a clogged or dirty air filter? It did not but the cars still run. If you put in a K&N air filter there would be a difference in the original Baro reading wouldn’t there, but the car still runs without any noticeable changes.The IAT is similar in the same regards. The IAT should not have been installed before the turbo, or the intercooler. We want the temp. of the air going through the intake to make A/F ratio calculations right. Do you think that the ECU known how much temp. rise the turbo is adding to the air temp, how about how much the intercooler is reducing the air temp at different outside air temps.. These old ECU systems are just that, old and outdated by today’s standards.I am using set points with the Gen II for the IAT and BARO. to match my location. Is this perfect? no but I would guess that it is pretty close compared to the old sensor readings with all of their design and location flaws. The way I hooked everything up the baro and ECU will calculate the altitude close to the original setup if not better and the IAT should have much more accurate readings if installed in the intake or close to the throttle body. Using set points with the Gen II and not using the grey and brown will not give double compensation.This is just my opion. -
Hi, That is correct it is Daniel -
There is no MAP sensor with this setup. -
Here is some notes of a install of a MAF translator Gen II I did. This is how I installed my mass airflow translator generation 2 on a 89 conquest TSI or starion. First I removed the kick panel on the passenger side and unpluged the two connectors use from the ECU. I have included pictures of all the connectors involved with this install. You will need to run a new 14 to 18gauge wire from the distributor harness plug wire-to-wire on the hardware side to the inside of the passenger compartment. I ran mine to be ECU location. I have a wideband O2 sensor I will be using during this install. I will also use a 3" GM MAF sensor and a GM map or barometer sensor and a IAT sensor. wiring from the translator: 1. connect the pink wire to the smaller ECU connector (A36) pin 1 which should be a red wire 2. connecting black wire to connector pin 2 3. connect the blue wire to the larger ECU connector (A37) pin 15 4. connect the orange wire to the 0-5 V output wire from your wideband controller 5. connect the purple wire to connector A36 pin 2 6. connect the white wire to the wire you run from the distributor connector 7. connect the green wire to connector is A37 pin 2 in this step you will physically cut the white wire with black stripe and connect the green wire to the wire from the connector to the ECU. 8. connect the yellow wire to the wire you just cut in the previous step that runs to the MAF sensor 9. brown wire not used 10. grey wire not used wire of the old MAF plug to the new barometer, IAT and MAF: cut the wires one at a time because there is 2 blk-wht wires and 2 grn-red wires (look at tht pictures) 1. take the red wire going to the old MAF sensor and cut it and hook it to the 12 V in of the GM's mass airflow sensor 2. take wire-to-wire with black stripe and cut it and hook it to the output wire from the GM's mass airflow sensor 3. hook the Gm MAF sensor ground wire to sensor ground wire fron the old MAF sensor wiring harnes 4. Hook the IAT sensor to the sensor ground wire from the okd harness 5. hook the IAT other wire to the green- red wire going to the ECU pin 5 6. hook the MAP or barometer sensor output wire to the blk-wht wire from the old wiring harness 7. hook the MAP or barometer sensor ground wire to the sensor ground wire from the old wiring harness 8. hook the MAP or barometer sensor 5 volt supply to the grn-red sensor power wire from the old wiring harness doing this will return all the sensor inputs that was lost in removing the orignal MAF sensor. Because the old MAF has the baro. and IAT sensor built into it. It is a good idea to install the new IAT in the intake or just before the throtle body, or anywhere after the intercooler. This way you will be gatting a truer temp reading of the incoming air to the engine. http://thestarquestclub.com/images/ecu_connector_a36.JPG http://thestarquestclub.com/images/ecu_connector_a37.JPG http://thestarquestclub.com/images/maf_connector_a67.JPG I hope this will help you during your install. I set the V1 and V2 to setpoint on thg Gen 2 Translator I am still working on ALL the other settings Let me know if this helps you or if you hane any questions. http://handymandan.us
You have a 4G64 2.4 wide block and are using a 4G63 2.0 head right. The 4g64 block was not machined for the oil squirters because it was not a turbo charged engine but it has the bosses for oil squirters but has not been machined for them. You need the bolts and washers and squirters. The machine shop will need the bolt so they can tap the right threads and tap in the right location. I do not have any engine parts but I am sure that someone here will have some. The G54B parts will work for you for this. You might want to edit the title of your post or start another thread, members might not know that the parts for the G54B will work for you. Good luck
Thanks nomad for the nice comments. Daniel
Hi Rob, I just wanted to say that if I had the funds I would gladly buy the car back from you. I did buy myself a Goldwing and still have it. I wish you well with the sale. Daniel
I am glad to hear that.
Is this what you are looking for? If so I will take $12 plus $7.50 dollars for priority USPS shipping. LMK http://thestarquestclub.com/images/mycarparts/P6204325.JPG
Hi there stranger. I have one, it dose have a broken bolt in the plate for the internal wastegate valve cover plate but should come out. $20 plus $7 shipping LMK Daniel
1987 Conquest TSI with no rust Custom MPFI MegaSquirt
kf4eok replied to kf4eok's topic in Cars for sale
The car has sold. Thanks everyone -
I wanted to change the title of this topic but the full editor dose not appear to be working as it should. I cannot access it at all If any Admin. can change it I would like it to read: Many parts for 1987-1988 for sale. Thanks
I sold the complete car and no longer have those parts. I do have a set of rims and will get pictures up soon with prices. Thanks
I sold the complete car and I have no other air dams as of now. thanks
SOLD rear transmission mount $8 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134308.JPG SOLD front strut rod set with bushings $10 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134311.JPG SOLD cowling plates $5 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134312.JPG set rocker arms like new $25 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134313.JPG set of new hyd. lifters $20 plus shipping. NO Picture.
SOLD right side driving / fog light $12 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134298.JPG SOLD left side driving / fog light $12 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134297.JPG SOLD driving / fog light housings set $10 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134299.JPG SOLD driving / fog light trin set $10 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134300.JPG SOLD engine mount set $10 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134301.JPG SOLD rear end rubber mounts $15 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134302.JPG SOLD rear end mount brackets $8 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134310.JPG SOLD A/C adjustment pulley and bracket $12 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134303.JPG SOLD brake master clyinder resivor $8 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134304.JPG SOLD lower oil cooler mount $1 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134305.JPG SOLD clutch clyinder resivor $4 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134306.JPG
SOLD steering colum with lock cly and cey and coupler $50 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134290.JPG SOLD three port waste gate actuator $8 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134291.JPG SOLD interior door lock set $12 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134292.JPG SOLD exterior door handle set $15 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134293.JPG SOLD door lock actuators set $16 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134294.JPG SOLD left side door latch $5 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134295.JPG SOLD right side door latch $5 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134296.JPG
SOLD support in front of radiator $8 plus shipping. http://thestarquestclub.com/forums/images/smilies/thumb.gifhttp://thestarquestclub.com/images/mycarparts/P6134273.JPG SOLD front lower ball joint left side $12 plus shipping. http://thestarquestclub.com/forums/images/smilies/hand.gifhttp://thestarquestclub.com/images/mycarparts/P6134275.JPG SOLD water pump pulley $8 plus shipping. http://thestarquestclub.com/forums/images/smilies/juggle.gifhttp://thestarquestclub.com/images/mycarparts/P6134276.JPG SOLD front lower ball joint right side $12 plus shipping.http://thestarquestclub.com/forums/images/smilies/spit.gifhttp://thestarquestclub.com/images/mycarparts/P6134277.JPG engine oil pickup tube $10 plus shipping. http://thestarquestclub.com/forums/images/smilies/ranger.gifhttp://thestarquestclub.com/images/mycarparts/P6134278.JPG good used oil pump $25 plus shipping. http://thestarquestclub.com/forums/images/smilies/plane.gifhttp://thestarquestclub.com/images/mycarparts/P6134279.JPG SOLD front control arms pair $20 plus shipping. http://thestarquestclub.com/forums/images/smilies/director.gif http://thestarquestclub.com/forums/images/smilies/noidea.gifhttp://thestarquestclub.com/images/mycarparts/P6134280.JPG
ALL PARTS HAVE BEEN SOLD brake booster $35 plus shipping. http://thestarquestclub.com/images/mycarparts/P6134281.JPG A/C line $10 plus shipping. http://thestarquestclub.com/images/mycarparts/P6134282.JPG A/C line $10 plus shipping. http://thestarquestclub.com/images/mycarparts/P6134283.JPG A/C line $10 plus shipping. http://thestarquestclub.com/images/mycarparts/P6134284.JPG A/C line $4 plus shipping. http://thestarquestclub.com/images/mycarparts/P6134285.JPG A/C line with pressure switches $25 plus shipping. http://thestarquestclub.com/images/mycarparts/P6134286.JPG
ALL PARTS HAVE BEEN SOLD SOLD Trim around tag $15 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134263.JPG SOLD Intake manifold $15 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134264.JPG SOLD throttle body $12 http://thestarquestclub.com/forums/images/smilies/thumb.gif plus shipping.http://thestarquestclub.com/images/mycarparts/P6134265.JPG SOLD 1987 manual transmission $35 plus shipping, can be picked for free!! http://thestarquestclub.com/forums/images/smilies/wacko.gifhttp://thestarquestclub.com/images/mycarparts/P6134266.JPG valve cover cleaned http://thestarquestclub.com/forums/images/smilies/becky.gif and beed blasted $20 plus shipping.http://thestarquestclub.com/images/mycarparts/P6134267.JPG power steering pump with pulley $25 plus shipping. http://thestarquestclub.com/forums/images/smilies/flame.gifhttp://thestarquestclub.com/images/mycarparts/P6134270.JPG
that sounds like allot of fun but what will she cost me over the years to matain? Will I be able to afford something like that? LOL -
I am giving it two weeks to sell the car as a complete running car if it doesn't sell then every part will sell. The parts will be sold to the first person that gets the funds to me once I post the part and price. If I receive payment twice for the part I will refund the late payment. I will mark all parts that I have received payment for as sold. Thanks for your interest.
Payment recieved and part shipped. Thanks
Here is the link to the part out thread I have started. http://www.starquestclub.com/forum/index.php?showtopic=121230 The car is still complete and I am looking at all offers and trades. let me know what you have to barter with. EXAMPLES: land cars boats jet ski trucks planes ham radios equipement tools girls hybrid car or truck electric car or truck solar equipement solar panels -
SOLDhttp://thestarquestclub.com/forums/images/smilies/yo.gif relay $2 plus shipping. http://thestarquestclub.com/images/mycarparts/P6124246.JPG SOLD seilonids $2 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124247.JPG SOLD interior door handle trin set of two $5 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124248.JPG SOLD coolant sensor for ECU $4 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124249.JPG SOLD coolant sensor $2 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124250.JPG SOLD vacum controll engine $4 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124251.JPG SOLD ABS inerica switch $5 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124253.JPG SOLD set of 4 relays $12 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124254.JPG SOLD temp. sensor in headlinner for A/C $4 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124255.JPG relay MB141967 $3 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124258.JPG 4 relays MB183865 $12 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124259.JPG relay $2 plus shipping.http://thestarquestclub.com/images/mycarparts/P6124260.JPG http://thestarquestclub.com/forums/images/smilies/hat.gif
