cengic@sbcglobal.net
Everything posted by cengic@sbcglobal.net
  1. Wow, seems like someone finally knows about wide block transmissions. What are the limits in horsepower and torque of the transmission?
  2. Rob, Thanks for the help offer. What I am looking for is the 2.6 wide block factory engine blueprint dimensions-specifically the rear engine/bellhousing area. I need these dimensions to make an adapter plate to adapt a 89 2.6 turbo trans to a Mazda 2.3 MZR engine. Please refer to my original May 28 6:08 PM post as well as button response May 28 9:28 Post#3. This is the info I need but for a wide block that was found in the D50 and Mighty Max. I you can help it will be greatly appreciated. You can only guess as to how much effort I have put in this project only to stall out at the finish line. Thanks very much Danny
  3. Anyone know where to find 89 Mighty Max or D-50 FSM?
  4. Still can't find the info i need. Post #3 from Button is what I need but for a wide block. Anyone have an idea what Mopar performance book this might be?
  5. Thanks for the info. It is what I need. The dimensions in the illustration do not match my transmission. Are they for a 2.6 Turbo 1989? What book are they from? Your help is appreciated. Sorry for getting back so late, I work construction and sometimes I don't get home weeks at a time. Thanks again Danny
  6. I am putting a 2.3 Mazda MZR turbo motor into a 1990 Mazda Miata. The MZR motor was originally installed east/west and the Miata is north/south. All available Mazda transmissions are capable of a maximum 250 hp/250 lb./ft torque. After that the aluminum cases spread and shear off the gear teeth. The MZR motor stock is past the capability of any available Mazda transmission. A couple of my workmates play with the 2.6 turbo boosted way over 300 hp and use the stock 5-speed. See where I am going? I have an 89 2.6 Turbo 5 speed trans. I am trying to adapt this trans to the Mazda engine. I am attempting to get the engineering drawings to make an adapter plate. I have the Mazda engineering drawings but have been unable to locate the 2.6 turbo dimensions. What I need is the engineering drawings showing the rear engine dimensions or the drawings showing the transmission bellhousing dimensions. Any suggestions as to where this information might be found? Thank you for your time and effort. Danny Cengic cengic@sbcglobal.net
