s_dime_man
s_dime_man's Achievements
ok damn non shp anything then.
ok it says 205/ 225 but it has 9 inch wide rears cause i measured them i own a tire machine;) and i know they came on the car cause i bought it off old ppl and i think they were original owners... so either way its a 1987 with shp wheels thanks for the correction now buy the car.!... plz
oh...?? how do you know if one is a shp then?
look at the pics.... not many i know. body is in great condition has 127,xxx one body unknown on engine. i have new timing chain and gears to put on but havent yet. car is 99% stock. http://s103.photobucket.com/albums/m130/sd...iafilter=images
FIP TBPRO-2 modded fuel rail and new injectors NIB
s_dime_man replied to NotStock88's topic in Parts for sale
i call dibs if the austin guy doesnt buy it.... -
i might pick this up from you but it wont be til the middle of this week. hope you still have it -
ok so what should my compression test psi be? gimme new motor and 150,000 mile motor numbers i will do the test in the morning.... thanks guys
just swapped engines in a quest.. changed oil and with in 800 miles my oil is very black. why? and i have went through 2 used slave cyl. for clutch these commonly go out??
ya i have another boost gauge haven't gotten around to putting it in. and about the vacuum, i have sprayed ether around all the connections and no change in idle.
car pulls no vacuum from anywhere accept the brakes....... and turbo will not spool past 7 on stock boost gauge even with line disconnected from wastegate...
when i yesyed mine one had 12.28 and the other like 5.somethin volt but how long has it been since the car ran last cause im still betting on the cone filter it only takes 10 mins total to remove the pump i would check that cone filter
ECU AND KNOCK/IGNITOR BOX FOR SALE..reduced..sale pending
s_dime_man replied to damurida's topic in Parts for sale
he just said 130 shipped. -
have you taken the inlet hose to the fuel pump that little cone filter could be clogged, mine was car ran similar
problem solved!!!! car runs decently now. it was nasty chunks of gas goo and varnish clogging up the cone filter. might drop tank soon. but for now i put an inline filter before the cone and went out tonight unregistered and did some amazing donuts!!! car isnt fast though, maybe its the 5 year old gas still in it but i wanna up the boost and fuel safely any tips??
dont know anything about it but pretty sure its fine i live in springhill fl. im young and never shipped anything large so you must arrange to be picked up.
