Fuzzydicerule
Everything posted by Fuzzydicerule
89 motor and 87 trans with 89 clutch
Fuzzydicerule replied to markhansenconquest's topic in Parts for sale
Pm'd -
Stumble from 1500-2000rpm
Fuzzydicerule replied to Fuzzydicerule's topic in Advanced Virtual Mechanic
Don't worry they are on my list of things to replace once I get some spare $ -
Thanks for the input guys I'll go ahead and check those things out today if I get a chance. -
I've checked for error codes and got a whole lot of nothing. So I was thinking about it maybe being a coolant temp sensor. Which one is the for the ecu? The two prong or one? -
The injector clips haven't been replace but I have tryed wiggleing them and evdrything and it did not stumble or anything. So yeah I know I should replace them but so far they haven't shown any signs of going out. -
Hey guys so looking to see if any one has any ideas for what is going on with this. The problem: So while maintaining a constant speed with the rpms between 1500-2000 the car will randomly stumble or buck. If you accelerate it is perfect all the way up. I've tried to watch my Afr gauge but it reads its typical for me --- under super light load so I don't know if it is 100% accurate. Things I've done: Had the tps upgrade on it. And set it to .5 volts same issue Changed it to a stock unit set to .5 volts l, same issue Triple checked timing at 10° It has trilogy turbos stock sized injectors a few years old now. Replaced vacuum lines I am kind of lost on this and any input would be awesome. Kind of hard to pass ca smog when you can't maintain a speed in that rpm range. Thanks for the help. Jeff
I had a clean set of tail lights. Should have thrown me a text.
GNT performance POLY bushings and Mounts
Fuzzydicerule replied to 19cturbo's topic in Vendors Listings
Might I suggest this getting moved to the vendors section. Easier to find there.- 151 replies
- engine mounts
- differential mounts
- (and 4 more)
I already got the oversized head from dad. Just need the bottom end cause mine has seen better days. Yeah saw his listing. Looking for something a little cheaper too. But thank you
Hi all. Looking for a good condition short block. I would prefer one with the complete rotating assembly but if the best I can find is a bare block I'll go that route. Hit me up. Thanks Jeff
What's the condition on that rear bumper skin? Paint good on it?
- 25 replies
- radio trim
- taillight trim
(and 1 more)
Tagged with:
Looks great man. Thank you for doing this. Seriously it is very appreciated
MotoCam360 Airdam brackets - Coming Soon
Fuzzydicerule replied to MotoCam360's topic in Group Purchase Info
I'd be interested -
How much for the HVAC assembly. Pretty much the boxes under the dash.
Still got one for an 87?
Payment sent
Just saw you sold the wheels nvm
Diff mounts, torque tube mount, shifter bushing, and short throw when available. Please and thank you
You selling my secondary air cleaner there Arron? Haha
TPS throttle position sensor replacment/upgrade kit.
Fuzzydicerule replied to boostinmini's topic in Group Purchase Info
I'm interested -
I'd be in for a set of poly
HVAC Controller self adhesive "Overlay" Kit
Fuzzydicerule replied to natallica's topic in Vendors Listings
Still available? -
New "Stedebani" GP. Feeler thread post up.
Fuzzydicerule replied to quikconq's topic in Group Purchase Info
Hey man I am in for 1. stedebani short throw shifter kit 1. poly ureathane suspension kit 1. poly trans mount 1. poly rear diff mounts 1. rear hub bolts (pair) 1. nylon shifter bushing 1. Torque tube bushings Thanks Jeff -
Pm'd
