86boosted Posted November 12, 2009 Report Share Posted November 12, 2009 i need some help i just got a 86 conquest and it misses out while driving like its not getting enogh fuel i changed the plugs to the injetocrs what else could it be the injectors are new it runs fine in boost but runs like crap wen not in boost Link to comment Share on other sites More sharing options...
newquest86 Posted November 13, 2009 Report Share Posted November 13, 2009 what injectors did you put it ? 86 uses 2 850 cc injectors black top stock . you also need to do a tps isc reset download the factory service manual in the faqs section thread is starquest newbee checklist there should be a link you need to copy and paste if you cant find it search for fsm make sure your timing is correct first Link to comment Share on other sites More sharing options...
86boosted Posted November 15, 2009 Author Report Share Posted November 15, 2009 there the stock injectors the were rebuilt and i just rebuilt the throttle body i dont know wat else to do im not shure if its the fuel or not but wen u drive it it will just start spittin and sputterin out of no where Link to comment Share on other sites More sharing options...
Indiana Posted November 16, 2009 Report Share Posted November 16, 2009 Might be blown headgasket or cracked head letting in coolant. You checked compression? You losing coolant? Link to comment Share on other sites More sharing options...
86boosted Posted November 16, 2009 Author Report Share Posted November 16, 2009 i havent lost any coolant i think it might be my spark plug wires i put a timing gun on my car and it didnt work put it on my cousins and it works does that mean bad plug wires Link to comment Share on other sites More sharing options...
mistapickles Posted November 16, 2009 Report Share Posted November 16, 2009 vacuum advance? I don't know why you think it's fuel, do you have an A/F gauge? Link to comment Share on other sites More sharing options...
86boosted Posted November 16, 2009 Author Report Share Posted November 16, 2009 no buts that everyone tells me around hereand i think my spark plug wires are junk and how do u check the vacuum advance Link to comment Share on other sites More sharing options...
MGrissom18 Posted November 16, 2009 Report Share Posted November 16, 2009 what injectors did you put it ? 86 uses 2 850 cc injectors black top stock . you also need to do a tps isc reset download the factory service manual in the faqs section thread is starquest newbee checklist there should be a link you need to copy and paste if you cant find it search for fsm make sure your timing is correct first Wait the 86 uses 2 Black tops? Does the 87 as well? Link to comment Share on other sites More sharing options...
dstar88 Posted November 16, 2009 Report Share Posted November 16, 2009 no, i believe the 87's use 1 black and 1 green. Daniel Link to comment Share on other sites More sharing options...
MGrissom18 Posted November 16, 2009 Report Share Posted November 16, 2009 no, i believe the 87's use 1 black and 1 green. Daniel Eh, ok just wondering couse when we got the 87 it had 2 blacks in it... We change it to 1 black and 1 green the same day.. Link to comment Share on other sites More sharing options...
Indiana Posted November 17, 2009 Report Share Posted November 17, 2009 You'll need a hand vac. pump. Pull vacuum on the adv. unit and see that it holds. If it doesn't its bad. The Vac. adv. is also boost retard timing too and that's why its important. It won't matter much you can still drive the car if the adv. part is working but when it reverses then you have issues under boost and higher rpms when the knock sensor goes off. All injectors "could" have black tops depending on if they have been re-manufactured or not. 86s should have two that have the letter "J" on then if its an intercooled car or perhaps "H" if not, J and H are very close in the amount they dispense if not the same. All the injectors are the same its just that tiny opening in the tip that is different. Link to comment Share on other sites More sharing options...
86boosted Posted November 17, 2009 Author Report Share Posted November 17, 2009 where do i get a hand vacuum pump Link to comment Share on other sites More sharing options...
Technology Posted November 17, 2009 Report Share Posted November 17, 2009 If you have old crusty, cracked spark plug wires, you should replace them. Check the jet valves for damage, do a compression test. And it could be bad injector(s). Link to comment Share on other sites More sharing options...
86boosted Posted November 19, 2009 Author Report Share Posted November 19, 2009 if u unhook the vacuum line from the vacuum advance valve should it run different cause i took the hose off mine and it didnt change anything ran the same Link to comment Share on other sites More sharing options...
Indiana Posted November 19, 2009 Report Share Posted November 19, 2009 No it makes no difference at idle if you remove the hose to the vacuum advance unit that is unless you leave the end of the hose open it might. At idle there isn't enough vacuum to cause it to change timing and it makes no difference if you have a leaky one at idle the leak couldn't be that big. You shouldn't be able to tell any difference. Link to comment Share on other sites More sharing options...
86boosted Posted November 19, 2009 Author Report Share Posted November 19, 2009 welli dont want to buy a new vacuum advance unless thats my problem cause there not cheap so i need help its still spittin and sputterin wat could make it do that Link to comment Share on other sites More sharing options...
86boosted Posted November 20, 2009 Author Report Share Posted November 20, 2009 does any body know wat it could be cause im goin to buy parts today it spitts and sputters like its not getting fuel but the spark plugs are black so wat else could it be Link to comment Share on other sites More sharing options...
mikec Posted November 21, 2009 Report Share Posted November 21, 2009 Spitting and sputtering can be over-rich too - flooding out. That leads to black plugs too. Leaking injector, miserable ignition timing, vacuum leaks ANYWHERE, a plugged fuel return hose leading to excess fuel pressure, etc. mike c. Link to comment Share on other sites More sharing options...
Indiana Posted November 21, 2009 Report Share Posted November 21, 2009 86 fuel system is easier to flood out like the 83 - 85 too because the injectors dispense larger amounts of fuel one then the other and repeat where the 87-89 system uses a sligtly smaller opening injector that fires all the time. Those larger opening injectors being dirty very quickly make for a flooded car. Even the 87+ with a dirty primary can foul plugs. Might need to have those cleaned. Link to comment Share on other sites More sharing options...
