ENGINE BAY UPDATED
VICE
Note the before and after pics of the distributor and the MSD EDIS coil pack.. And billet aluminum crank pulley and VR sensor and bracket.
Before
http://lh4.ggpht.com/_hllfg0A_1bY/SuEjLLqCKDI/AAAAAAAABDM/2rigjON7Yq4/s800/GEDC0949.JPG
After
http://lh4.ggpht.com/_hllfg0A_1bY/SvHPHtv0SlI/AAAAAAAABEc/RZl_OqRroMs/s800/Bay4.JPG
Ford 75mm TB =D
http://lh4.ggpht.com/_hllfg0A_1bY/SvHPQoSoEnI/AAAAAAAABE8/UXgv4NCrDGs/s800/Bay3.JPG
More Mookeeh Products Billet crank pulley with built in Trigger Wheel
http://lh5.ggpht.com/_hllfg0A_1bY/SvMRmiAfUeI/AAAAAAAABFg/H31sHwi2ADs/s800/VRsensorPulley.JPG
And VR Sensor Bracket..
http://lh6.ggpht.com/_hllfg0A_1bY/SvMR7oSAXKI/AAAAAAAABGA/ABEhzwAPIqs/s800/BilletCrank.JPG
Edited by VICE
They are Magnecor.com 8.5mm wires I got them on Ebay. http://cgi.ebay.com/ebaymotors/MAGNECOR-SPARK-PLUG-WIRES-91-92-93-94-95-96-ESCORT-1-9_W0QQitemZ200362492969QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item2ea6890429
They are pretty neat if you can notice on the pic 3 of them come with the elbow to stick into the spark plug and one of them, on spark plug #1, is a straight boot like my other set was..
Edited by VICE
Vice,
Were you using a magna distributor? How did you have your distributor setup for ignition? Thanks
Braden
What is a Magna distributor? I had the stock ignition system then I went EDIS when I had the MS put in.. NOTE: Not only is my car not running right, the turbo where it meets the manifold is GLOWING RED everytime I'm done driving. I need this fixed FAST and I can't go to no $175 per hour Dyno Tune right now..
Vice...This can be running too lean....or timing is advanced too much......If you have the same VE map I would say you need to take some timing out on your ignition map...Check out the MPI forum with the maps section...psu_crash has a pretty safe ignition curve posted on there....Post your settings up.
He should be running the exacr same ignition map as my car, which is super safe
Edited by jahjah
