artinist Posted October 2, 2009 Report Share Posted October 2, 2009 (edited) Suspension Techniques Sway Bars. Fronts and rears with the correct connecting bolts and spacers, the ones included with new kits are the wrong ones and you have to buy a seperate generic kit from pepboys to make it fit right. $180 plus shipping Edited October 23, 2009 by artinist Quote Link to comment Share on other sites More sharing options...
spoolinturbo Posted October 2, 2009 Report Share Posted October 2, 2009 pix please Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted October 3, 2009 Report Share Posted October 3, 2009 Suspension Techniques Sway Bars. Fronts and rears with the correct connecting bolts and spacers, the ones included with new kits are the wrong ones and you have to buy a seperate generic kit from pepboys to make it fit right. These are the newer Gray bars, not the old Blue ones. $200 plus shipping CRIPES!!! Where were you with these 3 months ago??? I just bought a set from ADDCO and paid out the anus for them. Quote Link to comment Share on other sites More sharing options...
klockimofog Posted October 3, 2009 Report Share Posted October 3, 2009 How long did you run these? and pics would be nice. Quote Link to comment Share on other sites More sharing options...
BIL Posted October 3, 2009 Report Share Posted October 3, 2009 Hey Art, since i didn't get any of the other stuff... I'll take the sway bars. Shipping to 33611. Let me know the total and I'll get the money out to you. Quote Link to comment Share on other sites More sharing options...
artinist Posted October 19, 2009 Author Report Share Posted October 19, 2009 sorry about delay was away for work. ok, I should have informed myself about these parts before posting, the rear one is not as new as the front one and it could use a set of end bushings. I will knock the price down to $190. shippng will be $25 http://i719.photobucket.com/albums/ww195/artinism/swaybars.jpg Quote Link to comment Share on other sites More sharing options...
Killtodie Posted October 19, 2009 Report Share Posted October 19, 2009 hmmm, I just bought some from ST directly and they were green. Also I had no issues mounting them although it didnt come with rear poly bushings for the bars themselfs but my stock ones were in good shape. Quote Link to comment Share on other sites More sharing options...
pitboss Posted October 19, 2009 Report Share Posted October 19, 2009 (edited) hmmm, I just bought some from ST directly and they were green. Also I had no issues mounting them although it didnt come with rear poly bushings for the bars themselfs but my stock ones were in good shape. Yeah, they've been green for a few years now. I had mine installed with new struts and springs like 3 years ago. They were green, came with red poly bushings and all new mounting hardware and fit fine. Their kit doesn't come with 2 mounting poly bushings or 2 mounting brackets for the back bar though. You have to reuse your stock ones. You can get new rubber bushings from autozone though. Edited October 19, 2009 by pitboss Quote Link to comment Share on other sites More sharing options...
Killtodie Posted October 19, 2009 Report Share Posted October 19, 2009 The only thing mine didnt have were teh rear poly bushings, came with the front. Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted October 19, 2009 Report Share Posted October 19, 2009 The ADDCO bars came with all the bolts, poly bushings and the front U Clamp but I just used the factory U clamp as it has the bolt hole for the metal cover. The rear bar you just use your factory clamp and the poly bushings you get in the kit were like see through they were so thin but worked great. To use your factory front U clamp just get a few thick washers and space it out a little bit, it worked perfectly. Quote Link to comment Share on other sites More sharing options...
pitboss Posted October 20, 2009 Report Share Posted October 20, 2009 The only thing mine didnt have were teh rear poly bushings, came with the front. So your ST swaybars didn't come with rear poly bushings (mine didn't either) but you did get new rear brackets? If so, that's new. Quote Link to comment Share on other sites More sharing options...
pitboss Posted October 20, 2009 Report Share Posted October 20, 2009 The ADDCO bars came with all the bolts, poly bushings and the front U Clamp but I just used the factory U clamp as it has the bolt hole for the metal cover. The rear bar you just use your factory clamp and the poly bushings you get in the kit were like see through they were so thin but worked great. To use your factory front U clamp just get a few thick washers and space it out a little bit, it worked perfectly. My front ST swaybar uses the new front U brackets that came with my kit, but you do still have to use your stock bushing spacer that is used under the bushings and new U brackets. I must be missing an air diverter or something since nothing bolts to those nuts welded into the stock U brackets, so the new U brackets worked fine in my case. Also, the Addco's kit sounds like theirs is more complete than ST's kit. Quote Link to comment Share on other sites More sharing options...
artinist Posted October 23, 2009 Author Report Share Posted October 23, 2009 price reduced to $180. Quote Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted October 23, 2009 Report Share Posted October 23, 2009 maybe someone would buy them and other items you have if you'd return multiple pm's sent to your inbox Quote Link to comment Share on other sites More sharing options...
artinist Posted October 24, 2009 Author Report Share Posted October 24, 2009 Hi, sorry the inbox is nearly full. i have tried to respond on first come bases. Quote Link to comment Share on other sites More sharing options...
Killtodie Posted October 24, 2009 Report Share Posted October 24, 2009 So your ST swaybars didn't come with rear poly bushings (mine didn't either) but you did get new rear brackets? If so, that's new. sorry for being a nub, but what are the rear brackets? Here is what it came withhttp://lh3.ggpht.com/_DE6W0quWtjY/SpnlyE0xrcI/AAAAAAAAKx0/qrex-xxtZDY/s800/IMG_6107.JPGAll set of endlinks and only front poly bushings, I reused the rear ones which were in good condition. I used the stock metal clips that hold it in place, are those the brackets you are talking about? I dont see a reason that I need different ones.. Do explaine Quote Link to comment Share on other sites More sharing options...
artinist Posted October 26, 2009 Author Report Share Posted October 26, 2009 the endlink bolts and spacers that they ship with do not match up when you try to install them, one is too short, one is too long,etc. the bolts they send with the font kit is a joke. even after tightening all the way till there are no threads left, the thing is way loose. you have to mix some stock ones and some of theirs to make the appropriate length. i had a thread on this topic but can't find it. Quote Link to comment Share on other sites More sharing options...
mistapickles Posted October 26, 2009 Report Share Posted October 26, 2009 (edited) the endlink bolts and spacers that they ship with do not match up when you try to install them, one is too short, one is too long,etc. the bolts they send with the font kit is a joke. even after tightening all the way till there are no threads left, the thing is way loose. you have to mix some stock ones and some of theirs to make the appropriate length. i had a thread on this topic but can't find it.PM me your phone number, I will come pick them up. I want the sway bars and the clutch Edited October 26, 2009 by mistapickles Quote Link to comment Share on other sites More sharing options...
havic64 Posted November 22, 2009 Report Share Posted November 22, 2009 Hello, do you still have these... Quote Link to comment Share on other sites More sharing options...
scotty Posted November 22, 2009 Report Share Posted November 22, 2009 Hello, do you still have these... he does not reply to PM's after reading them etc dont bother wasting your time. Quote Link to comment Share on other sites More sharing options...
havic64 Posted November 22, 2009 Report Share Posted November 22, 2009 he does not reply to PM's after reading them etc dont bother wasting your time.I try too reply but for some reason we never got connected...sorry... Quote Link to comment Share on other sites More sharing options...
havic64 Posted November 22, 2009 Report Share Posted November 22, 2009 I try too reply but for some reason we never got connected...sorry...I am still interested if you still have them... Quote Link to comment Share on other sites More sharing options...
artinist Posted November 23, 2009 Author Report Share Posted November 23, 2009 Hi, sorry I meant to post that they are sold. I do my best to answer the PMs in order from whoever is first and then whoever actually pays first. I have had several people say they are paying with money orders for a part and then i wait a week and nothing. I have also had to post only a couple of items at at time and even then I have to try not to go over the limit in the PM inbox. For the heavier items I have been giving priority to the local pick ups. Quote Link to comment Share on other sites More sharing options...
