VDub VR6 Supercharged
StarionPAP
I tried with a friend of mine with a VW Supercharged VR6 MKIV. That VR6 is very torquey, spitts flames and all. Pretty fast. We tried a standing start. He took the jump on me until, and I couldn't come back from it. Got me on the first try 1 car's lenght. We tried a second time, rolling start from 1st gear. Punched in 2nd, neck and neck, 3rd, neck and neck, fourth gear, got maybe 15 inches in fron of him. Was niiice. Was boostin' 15 lbs. Just wanted to share. The guy never thaught that the old' lady had it in her. He was very impressed. Some friends of mine told me I even spitt a little fire when we let off the gaz after the first run. Till next run!
J-Mike
PAP, Haiti
It was a GTi.
Next month, since I can't go MPI yet, I want to try to go to 2 secondaries with the MAF-T and Wideband, see how it goes. Maybe try to up the boost a bit to 18 psi?? That is the best option if you don't go MPI, too bad our TB are so small.
Which injectors are you running?? Trilogy Turbos?? I got a Bosch Fuel Pump (TEP), and Aeromotive RRAFPR, and also a built bottom end (Forged Wiseco's with DAD's race prepped rods).
Primary
http://www.racetronix.com/17113814FM.html
Secondary
http://www.racetronix.com/17113744FM.html
I did some minor drilling to get them to fit on the top portion of the TBI
Also check this out for more info
http://starquest.i-x.net/viewtopic.php?t=1031
Edited by BRAZILBOY
Did you bump the fuel pressure?? When you boost are you runing rich on your A/F Meter with those inj.?? I've seen on this site that the flow pattern on stock mitsu injc. are better. Are you running a 1G MAS of a MAF-T 3"? Those Racetronix inj. look nice, and the price is not bad 2. Thanks for the info. Edited by StarionPAP
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
