Professor Posted June 23, 2008 Report Share Posted June 23, 2008 I have looked in the 86 and 88 manual and I find nothing on the oil squirters. I want to know the torque specs on them When I tighten them down, they get to a point and then the nut turns. What is the proper way to install these things? Link to comment Share on other sites More sharing options...
Indiana Posted June 23, 2008 Report Share Posted June 23, 2008 (edited) before you put them back in lets assume you have cleaned them, depressed the valve in the bolt and flushed it, blown pressurized air and some type of solvent through the jet per the factory engine rebuild manual they didn't list a spec but they said it was fine to reuse the two old aluminum washers and you tighten them until the washers start to mash outward, they use two washers one above and one below the jet there is a spec I don't know what it is, I just did it like they said if it mashes out good if not maybe that torque spec isn't enough, someone will post it they are rights and lefts http://www.b2600turbo.com/images/IM000256.JPG Edited June 23, 2008 by Indiana Link to comment Share on other sites More sharing options...
Dad Posted June 23, 2008 Report Share Posted June 23, 2008 I don't know where they got the spec but AERA has it listed to torque the squirters 21-22 ft lbs. That has always worked for me. Dad Link to comment Share on other sites More sharing options...
Professor Posted June 24, 2008 Author Report Share Posted June 24, 2008 Thanks everyone! I just torqued them to 28 lbs. I just thought something was wrong when they kept turning. I thought it might be adjusting the pressure on the built in valve. Link to comment Share on other sites More sharing options...
