lsdmane Posted May 15, 2008 Report Share Posted May 15, 2008 im getting ready to buy an 86 dodge conquest i know absolutely nothing about these cars i figured why not look around here i have 2 questions 1. would this car have a carb. and if it doesnt what kind of efi is it 2. whats the bolt pattern for the wheels Link to comment Share on other sites More sharing options...
StrayWolf83 Posted May 15, 2008 Report Share Posted May 15, 2008 Hello ,.... Welcome to the club for starter. I am no expect with the Starion/Conquest car yet, only been a member since last year but I will try to help you out the best i can. Question #1 - The engine youa re asking about is the stardard 4G54 2.6 L I4 with TD05-12A turbocharger = single-camshaft head (SOHC) rather than the dual cam head, using a throttle-body fuel injection setup which mixed the fuel with the air prior (2 injector set-up). Question #2 - Bolt pattern and wheels for the 86 - depending on if the car is running an intercooler or no intercooler. Wheel Size 6-JJx14 (4 bolt 6" wheel) 6.5-JJx15 (4 bolt 6.5" wheel) 6.5-JJx15 (5 bolt 6.5" wheel) Bolt Pattern 4 x 114.3 mm 5 x 114.3 mm Hope this help. (If I am wrong the other quest member will jump in to correct me) Link to comment Share on other sites More sharing options...
Tman Posted May 15, 2008 Report Share Posted May 15, 2008 Hello ,.... Welcome to the club for starter. I am no expect with the Starion/Conquest car yet, only been a member since last year but I will try to help you out the best i can. Question #1 - The engine youa re asking about is the stardard 4G54 2.6 L I4 with TD05-12A turbocharger = single-camshaft head (SOHC) rather than the dual cam head, using a throttle-body fuel injection setup which mixed the fuel with the air prior (2 injector set-up). Question #2 - Bolt pattern and wheels for the 86 - depending on if the car is running an intercooler or no intercooler. Wheel Size 6-JJx14 (4 bolt 6" wheel) 6.5-JJx15 (4 bolt 6.5" wheel) 6.5-JJx15 (5 bolt 6.5" wheel) Bolt Pattern 4 x 114.3 mm 5 x 114.3 mm Hope this help. (If I am wrong the other quest member will jump in to correct me) you are correct very good info Link to comment Share on other sites More sharing options...
shift1313 Posted May 16, 2008 Report Share Posted May 16, 2008 the block is also referred to as the g54b-t(turbo). the motor came in a variety of other vehicles, dodge caravan, lebaron, other K cars, montero/raider, mighty max d50... most of those are carbbed non turbo versions of the same motor. Link to comment Share on other sites More sharing options...
FlattopMike Posted May 16, 2008 Report Share Posted May 16, 2008 the block is also referred to as the g54b-t(turbo). the motor came in a variety of other vehicles, dodge caravan, lebaron, other K cars, montero/raider, mighty max d50... most of those are carbbed non turbo versions of the same motor. Don't forget fork lifts! LOL Link to comment Share on other sites More sharing options...
lsdmane Posted May 28, 2008 Author Report Share Posted May 28, 2008 thanks guys Link to comment Share on other sites More sharing options...
