emagdnim Posted March 31, 2008 Report Share Posted March 31, 2008 Well, I figured everyone might want to know this... i have the mitsu cd and the truck codes from being a parts guy so why not... ill share. Montero with leaf springs: 83-87: Varies from year to year on what trucks got what. 4.625 = MB185463 4.875 = MB527147 4.222 = MB185462 Montero 3.0 with coil suspension: 89-91: all years one option. 4.625 = MB598210 Montero 3.0: 92-96: varies in different options for all years 4.625 = MB598210 4.875 = MB598487 4.636 = MR162750 Montero 3.5 DOHC: 94-00: 4.636 = MR124857 4.272 = MR296349 Montero 3.5 SOHC V6 24V: 01-02 Can't pull information up on this one yet. Montero 3.5 SOHC V6 24V: 03 Can't pull information up on this one yet. Montero Sport: 2.4: 2WD: 96-99: only one option for these years. 4.222 = MB185462 Montero Sport: 3.0: 2WD: 97-03: 4.222 = MR162749 4.636 = MR162750 4.900 = MR296348 Montero Sport: 3.5: 2WD: 99-03 4.272 = MR296349 4.636 = MR124857 Montero Sport: 3.0: 4WD: 97-03 Wont let you select the gears. Montero Sport: 3.5: 4WD: 99-03 4.272 = MR296349 4.636 = MR124857 4.900 = MR124858 Mighty Max: 2.0: SWB/2WD: 87-89: only one option. 3.909 = MB185461 Mighty Max:: 2.6: SWB/2WD: 87-89: only one option. 3.545 = MB185460 Mighty Max: 2.4: SWB/2WD: 90-96 only one option. 3.909 = MB185461 Mighty Max: 2.6: LWB/2WD: 87-89 3.545 = MB185460 4.222 = MB185462 Mighty Max: 2.4 LWB/2WD: 90-95 4.222 = MB185462 3.909 = MB185461 Mighty Max: 2.6 LWB/4WD: 87-89 3.909 = MB185461 4.222 = MB185462 Mighty Max: 3.0 SWB/4WD: 90-95 4.222 = MB527248 Mighty Max: 2.6 LWB/4WD: 87-89 3.909 = MB185461 4.222 = MB185462 Mighty Max: 3.0 LWB/4WD: 90-91 4.222 = MB527248 Well... now you know what gears come in what trucks... if you can update this thread with anymore information it will be appreciated! Link to comment Share on other sites More sharing options...
StarquestRescue Posted March 31, 2008 Report Share Posted March 31, 2008 (edited) Well, I figured everyone might want to know this... i have the mitsu cd and the truck codes from being a parts guy so why not... ill share. Montero with leaf springs: 83-87: Varies from year to year on what trucks got what. 4.625 = MB185463 4.875 = MB527147 4.222 = MB185462 Montero Sport: 2.4: 2WD: 96-99: only one option for these years. 4.222 = MB185462 Mighty Max: 2.0: SWB/2WD: 87-89: only one option. 3.909 = MB185461 Mighty Max:: 2.6: SWB/2WD: 87-89: only one option. 3.545 = MB185460 Mighty Max: 2.4: SWB/2WD: 90-96 only one option. 3.909 = MB185461 Mighty Max: 2.6: LWB/2WD: 87-89 3.545 = MB185460 4.222 = MB185462 Mighty Max: 2.4 LWB/2WD: 90-95 4.222 = MB185462 3.909 = MB185461 Mighty Max: 2.6 LWB/4WD: 87-89 3.909 = MB185461 4.222 = MB185462 Mighty Max: 2.6 LWB/4WD: 87-89 3.909 = MB185461 4.222 = MB185462 Well... now you know what gears come in what trucks... if you can update this thread with anymore information it will be appreciated! Nice list. I think only the 4 cyinder gear fit the starion. Looks like we have another source for the hard to find 4.22 with the 2.4 montero sport. Edited March 31, 2008 by StarquestRescue Link to comment Share on other sites More sharing options...
emagdnim Posted March 31, 2008 Author Report Share Posted March 31, 2008 Did you say something or? It's not there. Link to comment Share on other sites More sharing options...
StarquestRescue Posted April 1, 2008 Report Share Posted April 1, 2008 I edited my first post. A lot of good info here guys. Sam put some time into that. RIGHT CLIC AND SAVE. For you 4cyl truck guys the posi you want is found in the 4cyl monteros, it's a easy swap on to your ring gear. The bigger v6 rear axle from a mighty max should swap in to a 4cyl truck as well. Link to comment Share on other sites More sharing options...
TurboRaider Posted April 4, 2008 Report Share Posted April 4, 2008 (edited) Nice list. I think only the 4 cyinder gear fit the starion. Looks like we have another source for the hard to find 4.22 with the 2.4 montero sport. Gen 1 Monteros and Raiders with a 4 cyl engine use rear diff gears that are the same size as the large Starion diff. Gen 1 Montero / Raider with the V6: The gears in the front match up to the large Starion diff. 87-90 Monteros came with 4.62 gears. 86 and older with the 3 speed auto have should have 4.22 gears. 4.875 for the early Monteros are very rare and were part of the high altitude package. As far as I know they are no longer availible. 5.28 gears can be gotten from Australia. The best used 4.62 gears are from the front of a V6 Gen 1. Since the 4wd is part time the gears will have almost no wear on them. Kevin C Edited April 4, 2008 by TurboRaider Link to comment Share on other sites More sharing options...
emagdnim Posted April 4, 2008 Author Report Share Posted April 4, 2008 Great info! The more the better! Can somone list the Starion info in here as well... Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted April 7, 2008 Report Share Posted April 7, 2008 do all of these fit the quest diff? Link to comment Share on other sites More sharing options...
jd_stazza_brendan Posted April 7, 2008 Report Share Posted April 7, 2008 (edited) I know for sure that the 4.6 Gears fit inside the Large diff housing. My mate runs a 4.6 locked centre in his car. Mind you its in Australia, if that makes any difference. Edited April 7, 2008 by jd_stazza_brendan Link to comment Share on other sites More sharing options...
Komeuppance Posted April 10, 2008 Report Share Posted April 10, 2008 Here's what a local D50 guy and I measured, confirming that the 4bolt Starion diffs are more narrow than a MightyMax diff. -Robert Link to comment Share on other sites More sharing options...
Shelby Posted April 10, 2008 Report Share Posted April 10, 2008 you can't use the carriers but you can use the ring and pinion gears ,, thats what the list is for ring and pinion gear sets ...........not the complete carrier i've done 3 sets of 3'90 swaps and did not have to change any shim spaceing at all thats not saying that will be the case for all gear swaps Link to comment Share on other sites More sharing options...
Komeuppance Posted April 10, 2008 Report Share Posted April 10, 2008 Yeah, this thread is about info on mitsu rear diffs. I was confirming that the starion carrier is narrow, as there was some speculation and no solid answers, until we measured it and posted pictures. -Robert Link to comment Share on other sites More sharing options...
