4g63ESI-r Posted August 27, 2007 Report Share Posted August 27, 2007 after going through 3 12A's in a month i decided i had to do something different. so i threw a t3/t4 on it. so far its working great. right now it's dialed in with boost. the wideband reads 12:1 @ 16psi and leans out after that. i'll post some pics in a few days. and once i get the 6al and safc wired up i hope to put up some dyno numbers and 1/4 times. mods:1g mafblaster 2boost controllercustom t3/t4 manifold and d/pregular a** ebay t3/t4 mods in next few days:walbro pump2 secondary injectorssafc6al Link to comment Share on other sites More sharing options...
QuietQuest Posted August 31, 2007 Report Share Posted August 31, 2007 You could get a GM mass air sensor and the maftranslator thing that DSM guys use. You can tune with that (not as much as the safc though). Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 1, 2007 Author Report Share Posted September 1, 2007 i like the safc. it's working well. i got it all broke in and am going to the track sunday. i've got it dialed in nice and fat with a 11.6:1 afr @ 25psi and 15 deg timing. she ate up a 5.7 GTO last night so i'm hoping for good things Link to comment Share on other sites More sharing options...
jinx Posted September 2, 2007 Report Share Posted September 2, 2007 what killed three 12As... trying to run 20+ psi ?Exactly which ebay t3/t4 you're using and what rpm does it hit 25psi ?car should be a blast Link to comment Share on other sites More sharing options...
Alcyone Posted September 2, 2007 Report Share Posted September 2, 2007 mods don't include an upgraded block?? Link to comment Share on other sites More sharing options...
QuietQuest Posted September 3, 2007 Report Share Posted September 3, 2007 You don't need to upgrade the block, but maybe the pistons and rods. But as long as you run it rich with the tbi, it'll be fine. if it were MPI i'd suggest leaning it out. Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 3, 2007 Author Report Share Posted September 3, 2007 well i got back from the track. went a 14.0 @ 101 with a 2.3 60 ft. i can't get this thing out of the hole to save my life. no mods on the block. what i have listed is what i've done. 3 12a's died at the hands of 14 psi. i obviously have some more tuning to do for the 1/4 to get this girl off the line. but this thing is balls fast up top. i took down the 5.7 GTO from a 60mph roll it had a cam, intake, headers/exhaust maybe a 2 step will help me with spool off the line Link to comment Share on other sites More sharing options...
QuietQuest Posted September 3, 2007 Report Share Posted September 3, 2007 Don't worry about a 2 step, just let the air out of your tires. I did that and went from 35+ to 20 an the wheel hop basically disappeared. I think 15 psi would even be better. Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 6, 2007 Author Report Share Posted September 6, 2007 yesterday on my way home my secondary stuck...never seen that happen before :roll: . it was wide open too. the car would fall all over itself til like 10psi when it would get close to enough air. i put the wideband on it and was getting like 9.6:1 at idle. seems like if it's not one part failing its another Link to comment Share on other sites More sharing options...
QuietQuest Posted September 6, 2007 Report Share Posted September 6, 2007 You should get them fixed. Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 7, 2007 Author Report Share Posted September 7, 2007 just had them cleaned before i put them in. i took them back to the shop i had rebuild them...they say the solenoid is sticking. so i said f*** it and ordered a 75lb and 95lb delphi injectors. i also have a caravan head coming with arp gear but haven't decided on a head gasket yet. any suggestions? Link to comment Share on other sites More sharing options...
QuietQuest Posted September 7, 2007 Report Share Posted September 7, 2007 Stock mitsu. Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 7, 2007 Author Report Share Posted September 7, 2007 really? are they multi-layer steel? Link to comment Share on other sites More sharing options...
Scotty Dont Posted September 7, 2007 Report Share Posted September 7, 2007 with that much psi i would o-ring the block and run a felpro Link to comment Share on other sites More sharing options...
QuietQuest Posted September 7, 2007 Report Share Posted September 7, 2007 really? are they multi-layer steel? No, but they are great anyway. You can get MLS for the g54b though. Search around, I can't remember any web sites for it. Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 7, 2007 Author Report Share Posted September 7, 2007 i just can't see 25psi on a stock gasket for very long, ya know. i was leaning towards the ajusa gasket or the guy that midwest turbo offers. Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 8, 2007 Author Report Share Posted September 8, 2007 http://i226.photobucket.com/albums/dd164/quest4power/88starquest.jpg http://i226.photobucket.com/albums/dd164/quest4power/stariont3t4.jpg http://i226.photobucket.com/albums/dd164/quest4power/hoosierdaddy-1.jpg Link to comment Share on other sites More sharing options...
DSM RSM 89conquest Posted September 10, 2007 Report Share Posted September 10, 2007 I just ordered the gear for a T3/T4 conversion. Nice to see some one else is already having luck with a similar setup. It is also good to know the stock engine is that strong. Nice machine. I am curious to know how many miles your engine has as well as what kind of compression readings you are getting from each cylinder. Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 10, 2007 Author Report Share Posted September 10, 2007 well compression is a little slack cause the bottom end needs freshened up. there's like 135k or so on the motor. but that's to be expected on something with that mileage. Link to comment Share on other sites More sharing options...
QuietQuest Posted September 10, 2007 Report Share Posted September 10, 2007 Strange looking corrado ya got there. Do the slicks help? Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 10, 2007 Author Report Share Posted September 10, 2007 lol yeah. thats a customer car. i don't think slicks will help. pretty sure its just not making enough boost off the line. Link to comment Share on other sites More sharing options...
quikconq Posted September 22, 2007 Report Share Posted September 22, 2007 hey wats the update,,,come on,,,geez Link to comment Share on other sites More sharing options...
4g63ESI-r Posted September 24, 2007 Author Report Share Posted September 24, 2007 **UPDATE** my njv head is almost done its 3 angle valve job at the machine shop. i gave it a port/polish job and polished the bowls. i'm also getting the tops of the valve guides grinded down to accept my future cam's lift. my shop and i are gonna be at MIR in november for the import vs. domestic finals. if anybody from that area (budd's creed, maryland) is gonna be there lemme know. Link to comment Share on other sites More sharing options...
4g63ESI-r Posted October 22, 2007 Author Report Share Posted October 22, 2007 ok...it's running and i'm going thru break in. i found out that i ran that 14.0 with a blown hg and burnt rings :oops: ...in a few weeks we'll see what she does with a nice sealed engine :wink: Link to comment Share on other sites More sharing options...
