need some help and ideas
ok i just got my car togather and the first couple of dayz were awsome it pulled realy good at 5 to 10 psi for like two days i blew a pipe off at 10 psi and now its realy slow here are the mods
hurricaine mpi kit
t3t4 70 trim
walbor 255
fpr rising rate
msd 6al
act 6 puck
top end performance non jet valve head
278 cam 1mm oversized valves
stock bottom end
i want to eventually run like 15 to 20 but not till this problem is fixed
msd blaster 2 coil
and much more supporting mods what should i run and does anyone have any ideas for me thanx
Dan
p.s here are some old pics
http://s87.photobucket.com/albums/k140/1fastconquest/
the end of your IC pipes should look like this:
http://www.rgvimports.com/pics/javi/beadroller/1.JPG
if not, they need beeded.
more info on beading pipe:
http://www.roadraceengineering.com/eclipse.../icpipebead.htm
or did you put the pipe back on, and now its slow all of a sudden?
yes im running 10 psi right now and its not even pulling like it did at 6 psi before i blew of the pipe. I just dont get it becuse the car pulled realy good before this happend inless there are some vacume leaks i cant find our boost leaks, im out off ideas.
you live right near me u should come check it out sometime
also all of my pipes do have a lip on them
Thanx
Dan
