conquest_junkie Posted July 21, 2006 Report Share Posted July 21, 2006 ok guys, found a starion in pa that i am makeing a day to setup and go look at it.....body doesnt look bad from what i seen expect for it will need a front fender,rear tail lights and by the sounds of it it needs interior......problem is with this car is the rusted pass frame rail.....was wondering what u all thought of this....pic of this frame is at bottom of page... thanks,leo http://img224.imageshack.us/img224/9441/07140616045tc.th.jpg Quote Link to comment Share on other sites More sharing options...
Couth'nize Posted July 21, 2006 Report Share Posted July 21, 2006 That seems alot of work. What does the rest of the car look like? Might want to wait a little for a better car to pop up on the for sale forum. Quote Link to comment Share on other sites More sharing options...
kev Posted July 21, 2006 Report Share Posted July 21, 2006 It is very common for that to rust on these cars and is an easy fix. Check the drivers frame for the same thing as well. The drivers frame usually rusts on the inner side next to the slave cylinder. The drivers frame is harder to fix because the fuel lines run right against it. Cut out the rusted metal. Form a channel out of a piece of 1/8" stock and weld it in. This will be stronger than new. I repaired both rails on my daily driver with 1/8" steel in one day. I also repaired both rails in my 87 restoration project by drilling out the original spot welds, removing the rail and replacing it with an OEM unit. However Mitsubishi no longer carries the OEM rails. kev Quote Link to comment Share on other sites More sharing options...
kev Posted July 21, 2006 Report Share Posted July 21, 2006 Oh btw, where in PA is this car? Quote Link to comment Share on other sites More sharing options...
conquest_junkie Posted July 21, 2006 Author Report Share Posted July 21, 2006 near philly..... Quote Link to comment Share on other sites More sharing options...
