Technica_turbo86 Posted January 18, 2003 Report Share Posted January 18, 2003 I want to see a coil on plug (C.O.P.) ignition on a starquest. That'd be CRAZY! -Colt Link to comment Share on other sites More sharing options...
kev Posted January 21, 2003 Report Share Posted January 21, 2003 Well you could do that if you wanted. Check out the MPI forum. Depending on your engine management system, you may have to use coil on plug ignition. The SDS EM3 4F system runs two seperate coil packs, one pack runs two plugs. This is close to coil on plug and many members of this site have this system. I am pretty sure that some of the other engine management systems such as Haltech, etc. can be purchased to run coil on plug. However the gain is kind of minimum. I myself opted for the SDS EM3 4E system which still uses the dist. to fire but the dist. is gutted (no weights or anything). Everything else is done through the Hal sensor for the ECU. kev Link to comment Share on other sites More sharing options...
