LowandSlow Posted October 21, 2002 Report Share Posted October 21, 2002 i have a 4 guage power wire run for my 600 watt concept amp and i have been trying to find the best place to get through the firewall. The amp is pushing two american pro 12" in a custom built box. for mids and highs i have a memphis coponent system. 6"1/2s in the door and i am looking for a place to mount the tweeters. Sony headunit. If anyone has any tips on the firewall or the tweeters please let me know. Link to comment Share on other sites More sharing options...
Q Posted October 21, 2002 Report Share Posted October 21, 2002 I ran mine under the car and came through the grommet under the rear seat Link to comment Share on other sites More sharing options...
chuck641 Posted October 26, 2002 Report Share Posted October 26, 2002 theres a big pack of wires goin thru the firewall right by the steering column that i used .. and if ur car is automatic u can drill thru right under the brake fluid resivoir where the clutch master cylinder would normally go .. Link to comment Share on other sites More sharing options...
jpmilkovich Posted October 30, 2002 Report Share Posted October 30, 2002 i drilled a 1/2" hole through my fire wall for 4 gauge wire. if you move the brake fluid container you should see a roughed up spot below it and to the left next to the brake booster. drill there. on the interior at the fire wall on the otherside there is a flap cut out on three sides from the factory. that is where it is located on the inside of the car. i drilled mine from the inside. i hope that helps. josh Link to comment Share on other sites More sharing options...
