Questsi Posted April 20, 2005 Report Share Posted April 20, 2005 The SDS TPS wire has a red, green, and black wire. The new Ford pigtail has three white wires. How do they go? I know this has been answered too many times. Link to comment Share on other sites More sharing options...
Pr4mnceMan Posted April 20, 2005 Report Share Posted April 20, 2005 The SDS has how to check it with a ohm meter in there under the TPS section. I don't have it with me and I'm out of town so I don't want to tell you wrong. It also depends on how you mounted the throttle body. My TPS is on the passenger side of the intake. I think the top wire on it was ground, middle was signal and bottom was power? Thats with the clip on the passenger side. If the clip is on the driver side then it'll be the opposite and power will be on top. Grab a meter and test to be positive you got it right, otherwise you could fry SDS. Link to comment Share on other sites More sharing options...
Questsi Posted April 20, 2005 Author Report Share Posted April 20, 2005 Mines mounted where the TPS is on the driver's side. Thanks. Link to comment Share on other sites More sharing options...
Boosted_One Posted April 20, 2005 Report Share Posted April 20, 2005 Mines mounted where the TPS is on the driver's side. Thanks. Sweep it per SDS instructions. I did it and forgot off hand what went where. I could check but it's too damn windy to walk outside. Link to comment Share on other sites More sharing options...
Pr4mnceMan Posted April 21, 2005 Report Share Posted April 21, 2005 I tried to verify on mine but I got them all taped up so I couldn't see s*** captian. ;D Read the manual, its really simple. I had a friend searching this site for the correct wiring and I found out what was whate before he found anything solid to go by! Link to comment Share on other sites More sharing options...
