tux Posted August 4, 2003 Report Share Posted August 4, 2003 I happen to have one, and there is one on ebay right now just wondering if it looks to anyone like it may be able to be used as a stand alone fuel controller. it has dials to adjust injector flow rate, rpm it starts work at, beginning boost and max boost and ratio to which the flow should change to boost (w/ simulator which i have) it has map sensor, and a tach input. it looks like it could do it (just fuel) otherwise i'd go for megasquirt. but since i have this s*** and just need to figure out how to find more harnesses it looks like a viable option to me i dunno anyone have any thoughts? Link to comment Share on other sites More sharing options...
eeaston Posted August 4, 2003 Report Share Posted August 4, 2003 Sounds like an additional injector controller, It won't work stand-alone, but should work along with the stock comp to keep you from leaning out under boost. Link to comment Share on other sites More sharing options...
tux Posted August 4, 2003 Author Report Share Posted August 4, 2003 it is an aic. I can start the car w/ it and the stock clips removed it's just a little difficult to get it started, gotta tap the "test" button to force more fuel out (but those inj are smaller than i'm gonna run for mpi) and it will hold a "rough" idle and rev up quite nicely tho. Link to comment Share on other sites More sharing options...
ZeroKewl9 Posted August 13, 2003 Report Share Posted August 13, 2003 How much does something like this cost? Zero Link to comment Share on other sites More sharing options...
