knightrider Posted August 31, 2003 Report Share Posted August 31, 2003 Hi yall, I was shopping for rims and found the perfect set, but the offset is not our factory offset. Fronts are 17x7 with the correct bolt pattern but a 38 offset, and the rears are 17x8 with the correct bolt pattern and a 35 offset. Can I just throw these on, or is there something I must do to correct the offset? Thanks. http://www.adrwheels.com/wheels/?sfID1=12&sfID2=40 Link to comment Share on other sites More sharing options...
VenomV8Quest Posted August 31, 2003 Report Share Posted August 31, 2003 im not sure but i think with that much offset,they will want to stick out from under the wheel well.which wouldnt work. Link to comment Share on other sites More sharing options...
MontyTSI Posted September 1, 2003 Report Share Posted September 1, 2003 the correct offsets for our wheels are in the FAQ...but i believe they are 18 to the negative for the rear (8)..rear 9's are 0 offset..take alook at the FAQ it will give you all the info Monty Link to comment Share on other sites More sharing options...
Ryan_V Posted September 2, 2003 Report Share Posted September 2, 2003 our lug pattern is common and yes ADR will have a few sets that should fit. Link to comment Share on other sites More sharing options...
D_Venable Posted September 2, 2003 Report Share Posted September 2, 2003 Front 16x7 +18 16x8 +18 Rear 16x8 -10 16x9 0 Derek Link to comment Share on other sites More sharing options...
VenomV8Quest Posted September 2, 2003 Report Share Posted September 2, 2003 anyone have a list of the companies that have wheels to work on our car? Link to comment Share on other sites More sharing options...
D_Venable Posted September 5, 2003 Report Share Posted September 5, 2003 Ronal Simmons ROH Three that come to mind There are probably more Derek Link to comment Share on other sites More sharing options...
knightrider Posted September 11, 2003 Author Report Share Posted September 11, 2003 OK, maybe I should rephrase my question a little. Will the offset of these rims have any ill affect on fitment? Will they hit the springs? Will they ride funny? Come on guys, I really want these rims? Any help would be great from anyone that has put non-factory offset wheels. Thanks Link to comment Share on other sites More sharing options...
D_Venable Posted September 11, 2003 Report Share Posted September 11, 2003 They will fit with spacers. For the ones you listed you will need a 20mm spacer for the front and a 45mm spacer for the rear to get them to the stock offsets for those particular widths. If you don't get the spacers, I'm pretty sure they will rub on the spring, that is if they would even go in that far. If you paln on getting them, get spacers. Derek Link to comment Share on other sites More sharing options...
VenomV8Quest Posted September 11, 2003 Report Share Posted September 11, 2003 but wouldnt he need to get longer studs?with the spacers,the lugnut will not tighten down enough? Link to comment Share on other sites More sharing options...
D_Venable Posted September 13, 2003 Report Share Posted September 13, 2003 What I'm thinking about are the type that you bolt to the hub, then you bolt the wheel onto the spacer that has its own studs. At least I think they make them like that. Like these http://www.wheeladapter.com/images/Wheeladapters02.jpg Link to comment Share on other sites More sharing options...
redquest Posted September 15, 2003 Report Share Posted September 15, 2003 Yes that is what he would need I had them custom made for mine, Get good ones, not cheapies! Link to comment Share on other sites More sharing options...
VenomV8Quest Posted September 15, 2003 Report Share Posted September 15, 2003 whats our backspacing? Link to comment Share on other sites More sharing options...
