maf translator first generation
Got my maf translator wired up runs but not running  right, wires from car air cleaner are two green and with  red strip, two black with white strip, white with black strip and red  and translator wires are pink, green, black, gray and brown what wires go with each other. Could someone help so I can see  if wired right and what wire is left out.
87 to 89 Maf wires:
Plug position-Color-Function
1-White /black-airflow output
2-Large red-+12 volts
3-Green/red-baro sensor 5v power
4'Black/white--Ground
5-Black/white-Baro pressure out
6-Green/red-Intake air temp
Translator to harness
Pink goes to 2 for power
Black goes to 4 for ground
Green to 1 for airflow
Gray to 5 for baro fixed at 3.9v
Brown to 6 for fixed temp of 80
White not used, rpm sig does not work.
The 1st gen dsm tuning instructions are still available if you search.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
