1987 conquest still lean
1987 conquest runs a little butter since hook up maf translator white wire to rpm signal and went to rpm mode but say's needs good rpm signal where do i hook in to get best rpm signal.
Where to you currently have it connected? I'm not familiar with what type of signal the MAF-T wants. If VR signal will work you can tie into the stock pickup. I'm sure other's can answer better
maf translator instruction sheet says good rpm signal from crank/cam angle sensor or tach signal from power transistor module which I don't think conquest has these that I know of so now I hooked into white wire off neg. side of coil but instruction say no coil terminal hook up
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
