Subitsu Posted October 24, 2015 Report Share Posted October 24, 2015 (edited) I've been searching forums can't find anything on anyone running E85. If there is anyone, what injectors, fuel pump, fuel pressure do you use? And anything else is needed? Sorry I thought I put this in Advanced... Edited October 24, 2015 by Subitsu Link to comment Share on other sites More sharing options...
scott87star Posted October 24, 2015 Report Share Posted October 24, 2015 I do, you need an aftermarket tuning device, no way to do it on the stock ECU without help. I also run a flex fuel sensor so I can run E85, E10 or anything in between. Last time I checked I had E23 in my flatty. Fuel pressure is 38 psi at idle. Link to comment Share on other sites More sharing options...
Subitsu Posted October 24, 2015 Author Report Share Posted October 24, 2015 Ok thanks! I assume you have a fuel cell, or are you still using the stock tank? Link to comment Share on other sites More sharing options...
scott87star Posted October 24, 2015 Report Share Posted October 24, 2015 Stock tank on both cars, the mpi car is stock fuel system up to the engine bay using a magn intake and FPR. The throttle body car has aftermarket alcohol compatible fuel pump and FPR and I changed all the flex lines to fabric braided alcohol compatible lines with A/N fittings. Link to comment Share on other sites More sharing options...
Subitsu Posted October 25, 2015 Author Report Share Posted October 25, 2015 (edited) Ok good to know. When you say tuning device do you mean piggy back ecu? Or a programmer if they make them for our cars. Has anyone tried to use a Cobbtuning accessport or have something similar? Edited October 25, 2015 by Subitsu Link to comment Share on other sites More sharing options...
Edde Posted October 25, 2015 Report Share Posted October 25, 2015 Ok good to know. When you say tuning device do you mean piggy back ecu? Or a programmer if they make them for our cars. Has anyone tried to use a Cobbtuning accessport or have something similar? scott's the man to see about your ecu. check his sig line. Link to comment Share on other sites More sharing options...
scott87star Posted October 25, 2015 Report Share Posted October 25, 2015 Accessport? Oh my! You can't access a dinosaur, the factory ECU is a dinosaur. Link to comment Share on other sites More sharing options...
StarquestRescue Posted October 25, 2015 Report Share Posted October 25, 2015 These cars can be tuned to some degree with air flow correction tuning. This is what a safc, safc2 and neo afc do. a maft does the same, but uses's a gm air flow meter and then converts the signal to a karmen signal which is what the mitsu air flow meters output. These units are know as piggy back tuning systems. Link to comment Share on other sites More sharing options...
Subitsu Posted October 26, 2015 Author Report Share Posted October 26, 2015 Ok thanks for all the help! have the starion in storage for the winter. Just need to collect every part I can get a hold off lol Link to comment Share on other sites More sharing options...
