Funky Phil
FunkLab Flexible Power Steering Lines!
Nylon/ptfe lined powersteering hoses to replace your worn, dirty, leaky, rigid eyesores you call your power steering lines! These have a braided steel surround coated with an anti-chaff clear sleeve. So no getting hung up on stray wires.
The Funk Lab power steering lines employ all STEEL fittings and adapters. And the honor of being made in the USA! You can take advantage of this and route the lines any direction you choose!
There are already many of these in circulation with no complaints.
$185 shipped
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/DSCN4503_zpscn8qnspq.jpg
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black_zps449h5iyv.jpg
Lines can be purchased in a multitude of chaff wrap colors.
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/powersteering_zpsw0l6c4i2.png
High Pressure, Steel braided Line with steel ends and fittings
-PTFE lined and clear coated
$100 shipped
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/High%20Pressure%201_zpsfmbcthkc.jpg
Low Pressure, Steel braided Line with steel end and fitting, -PTFE lined and clear coated with bass slip-on nipple.
$100 shipped
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/Lowpressure_zps5xjy24on.jpg
$185 shipped for the set
**PM ME FOR PAYPAL INFO**
Edited by Funky Phil
  • 2 months later...
Install pics
Original lines removed. New fittings installed in steering gearbox.
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%201_zpscn9gv6vt.jpg
Attach new lines HAND TIGHT and route as preferred. Ensure there is no chaffing. (Lowpressure has a barb on the opposing end) (Highpressure line goes from powersteering pump to fore-most port of the steering gearbox. Low pressure is on aft port closest to brake booster and connects to the steering cooler)
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%202_zpsmhmkk95k.jpg
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%203_zpsxmf6dxj3.jpg
Attach hi pressure line to pump
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%204_zpsnod6uxxe.jpg
Using an "oil safe" line (5/16ID) connect low pressure line to cooling loop
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%205_zpsxqrllalf.jpg
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%206_zpsjbw0zd9p.jpg
Secure your hoses. You can pic these clamps at lowes.
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%208_zpshfxgcrhe.jpg
Or if you have a parts car, they are covered in these. I often use these for all sorts of hose/line routing.
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%209_zpswyx21zch.jpg
I only used the closed clamps on one line as I wanted all my lines tight against each other. The clamps spread them too far apart for my taste. All the other lines are then bundled using zipties.
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%2012_zpsgpyw9e1u.jpg
Now tighten all your connections and perform a system bleed.
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%2013_zps0jxu6gnr.jpg
Now go for a drive!
http://i1250.photobucket.com/albums/hh538/sqperformance/FUNK%20LAB/Power%20Steering%20Lines/black%2014_zpsradohq5b.jpg
8)
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
