Trilogy Injector Seal Replacement
SCillini
I received a used pair of the Trilogy injectors however the seals need replacing, both the top and bottom. I found a TB kit that includes the bottom injector seals, but wasn't sure if the top seals in the kit would fit the Trilogy injectors.
I found some old threads referencing a member for Trilogy Turbos however they haven't been active since 11/14.
Anyone know where I can get replacement seals for these injectors or what alternative applications would work?
Thanks.
I doubled up 2 skinny ones and it worked as well as the fatter o ring.
You have to grease the o rings every time or the will not seat right.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xdelphi+o+rings.TRS0&_nkw=delphi+o+rings&_sacat=0
