*SOLD*AMC Spain Marnal/Monsta Banshee set-up
notfried
Hey all. I have a Spain casting Marnal head with 500 miles on it that I am no longer needing. It is gasket matched ported on the exhaust side, using a flow bench, has 1mm over-sized stainless steel valves, Schneider heavy-duty springs, and was made for a high-lift cam. The cam is a Tim C. Monsta Banshee Roller cam (INT Duration @.050: .207° Seat-To-Seat: 265°, EXH Duration @.050: .196° Seat-To-Seat: 262°, INT Lift: .480 w/1.6 ratio rockers;, EXH Lift:.459, Lobe Center Separation: 111.5°, Degree intake Lobe to 107°, Power Range: 2500-6500RPM), the rockers are 1:6 3000GT rollers, and the gear is a MK1 from Mookeeh. All the intake/exhaust hardware came from Dad, along with lifters and Fel-Pro 9116 head gasket set. This head was bought from the "Marnal GP OG", Richie_Rich, back in the day, sat in a box on a shelf most it's life, and got finally strapped to an engine that the machine shop installed the rings upside down in. Hence the 500 miles and the soot in the chambers. I included a pic of the soot because underneath it it is perfectly clean, and it falls off easily. I have over $1500 invested in this head/cam set-up and am looking to get $950 shipped and insured (continental US). Here's some pics. Thank you and have a blessed day.
http://i85.photobucket.com/albums/k61/notfried/19126_946004952086033_1300947645577761121_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11127877_946004912086037_6125106262711539536_n.jpghttp://i85.photobucket.com/albums/k61/notfried/10420280_946004895419372_7337388523279718732_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11081046_946004882086040_5515029591966322676_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11081437_946004858752709_9131302519937521197_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11084270_946004835419378_1518888447213133192_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11133708_946004805419381_6383342337114360845_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11081361_946004792086049_8695328717371600265_n.jpghttp://i85.photobucket.com/albums/k61/notfried/10502486_946004465419415_5358873570842221190_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11134147_946004538752741_4518085174317736082_n.jpghttp://i85.photobucket.com/albums/k61/notfried/18915_946004768752718_4311894291661751461_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11081498_946025185417343_692370248185311202_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11082594_946025798750615_5697647407571953883_n.jpg
Edited by notfried
  • 3 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
