The Rabbit1 Posted March 16, 2015 Report Share Posted March 16, 2015 Did you check or replace with new oil pump? if so..Did you get the correct oil pump? Link to comment Share on other sites More sharing options...
Dad Posted March 16, 2015 Report Share Posted March 16, 2015 Need to clean out oil cooler and lines also, or all that crap will get washed back into your engine. Link to comment Share on other sites More sharing options...
importwarrior Posted March 16, 2015 Report Share Posted March 16, 2015 if the head has been milled or surfaced a lot it could cause a little slack.they sold a shim at one time to take up the slack or difference from the surfaced head. Link to comment Share on other sites More sharing options...
sn8kes Posted March 16, 2015 Author Report Share Posted March 16, 2015 Dad- no I didn't flush the oil cooler out after rebuild. I will do that before the finish of this year down. TSI-Tom--- yes I did put the washer in place Import Warrior- the head and block was surfaced while out. I was able to find a shim to take up space lost. I was thinking lastnite- and import warrior said the same thing this morning. And when I read it I was a little pi%* at myself, but it's what it has to be. With last issue I had, I think I possibly turned the crank the wrong way to get it back to TDC. And that's the cause of the slack. Beaten myself up here- still going to check all that has been mentioned while the TC cover is off. Didn't run long this way. Maybe 2miles before I was back at the house. Thank you for all yalls input. Link to comment Share on other sites More sharing options...
