danfev1985 Posted December 22, 2013 Report Share Posted December 22, 2013 Hi guys my names Danny, i recently acquired a 1988 conquest here in Pennsylvania. It's not currently running due to the starter going out, needing a new shifter and the vacuum lines were never put back after the engine was rebuilt and put back in the car. I've found the vacuum diagram online but i was just wondering if there was anyone in my area willing to help me put things back together, especially the vacuum lines. The starter i can do myself as well as the shifter but i think i'll need some help on the vaccum routing. i was told by the guy that i bought it from the it needs a canister that alot of the vacuum lines come route to. I am located in the Nazareth Pa area, if there;s anyone that can help me out or at least guide me in the right direction, it would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
ColdScrip Posted December 22, 2013 Report Share Posted December 22, 2013 An important question that greatly affects how many vacuum lines you will have is, are you keeping all of the EGR stuff on the car? This includes the black box near the distributor, the long pipe leading from the back of the downpipe, a black plastic part thats threaded into the intake, etc. Quote Link to comment Share on other sites More sharing options...
BC_99 Posted December 22, 2013 Report Share Posted December 22, 2013 (edited) Yep, these cars can run with very few vacuum lines (5-10) depending on what you want for creature comforts. Heat, A/C, cruise control, ect... I still need to get out in my shop and check on that shifter for you. Busy time of year. BC_99 Edited December 22, 2013 by BC_99 Quote Link to comment Share on other sites More sharing options...
danfev1985 Posted December 22, 2013 Author Report Share Posted December 22, 2013 An important question that greatly affects how many vacuum lines you will have is, are you keeping all of the EGR stuff on the car? This includes the black box near the distributor, the long pipe leading from the back of the downpipe, a black plastic part thats threaded into the intake, etc.im guessing yes on the egr valve, because i doubt it would pass emissions here in PA. Quote Link to comment Share on other sites More sharing options...
danfev1985 Posted December 22, 2013 Author Report Share Posted December 22, 2013 (edited) Yep, these cars can run with very few vacuum lines (5-10) depending on what you want for creature comforts. Heat, A/C, cruise control, ect... I still need to get out in my shop and check on that shifter for you. Busy time of year. BC_99yeah no problem, im picking the car up on Friday not to far away, just wanted to make sure i had everything in place to get her up and running again. i would love for it to at least have heat, no a/c i can kind of deal with, i can get rid of the cruise control as well, Edited December 22, 2013 by danfev1985 Quote Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted January 1, 2014 Report Share Posted January 1, 2014 From FAQ: http://www.starquestclub.com/forum/index.php?showtopic=117852&hl=vacuum Quote Link to comment Share on other sites More sharing options...
danfev1985 Posted January 12, 2014 Author Report Share Posted January 12, 2014 Hi guys i had a few more questions to ask you guys. Would i have to drop my fuel tank to get to my fuel pump or are they accessible from the back seat? Also I have a hose thats plumbed into the chassis of the car under the air can, where does that go to?Lastly im trying to keep my cruise control i have the vacuum line that goes to it, the canister and a small switch of some sort near the passenger side firewall right in the corner, where does the main hose that goes to all of these plug to for vacuum? Quote Link to comment Share on other sites More sharing options...
tankbob Posted January 12, 2014 Report Share Posted January 12, 2014 Hi guys i had a few more questions to ask you guys. Would i have to drop my fuel tank to get to my fuel pump or are they accessible from the back seat? Also I have a hose thats plumbed into the chassis of the car under the air can, where does that go to?Lastly im trying to keep my cruise control i have the vacuum line that goes to it, the canister and a small switch of some sort near the passenger side firewall right in the corner, where does the main hose that goes to all of these plug to for vacuum?Might be worth it to drop the tank, clean it and do the fuel pump at the same time. But when I did my fuel pump I cut out part of the hatch where the spare is right above the pump and accessed it that way. Quote Link to comment Share on other sites More sharing options...
danfev1985 Posted January 12, 2014 Author Report Share Posted January 12, 2014 Might be worth it to drop the tank, clean it and do the fuel pump at the same time. But when I did my fuel pump I cut out part of the hatch where the spare is right above the pump and accessed it that way.thanks, ill just drop it. im scared i might cut off to much or not enough and just create a whole mess for myself lol Quote Link to comment Share on other sites More sharing options...
BC_99 Posted January 13, 2014 Report Share Posted January 13, 2014 Might be worth it to drop the tank, clean it and do the fuel pump at the same time. But when I did my fuel pump I cut out part of the hatch where the spare is right above the pump and accessed it that way. I did the same thing on my first one too. But dropping the tank isn't that bad. It's easier than cutting the trunk floor then having to make a new access door, like I did. BC_99 Quote Link to comment Share on other sites More sharing options...
danfev1985 Posted April 6, 2014 Author Report Share Posted April 6, 2014 I did the same thing on my first one too. But dropping the tank isn't that bad. It's easier than cutting the trunk floor then having to make a new access door, like I did. BC_99changed my fuel pump and voila it started up and held idle. shut it of quickly due to an oil leak ( forgot to put my turbo draiin on),. gonna work on it some more today and finish it up hopefully. Quote Link to comment Share on other sites More sharing options...
